Speedo is off by 19 mph
Old Jul 5, 2014 | 10:07 PM
doc11965's Avatar
Exclamation Speedo is off by 19 mph
Hi All
Once again I am in need of help, I put a new face on my gauges
and I must bumped the speedo, because it is off by 19 mph
nothing else has been touched, stock tires etc.
is there a way to recalibrate the speedo..any help would be great
2006 f150 xlt 5.4 triton
Thanks Kevin
Old Jul 6, 2014 | 01:57 PM
ak_cowboy's Avatar
You need to pull the gauges out, remove the needle, and reposition it. If you use a tuner to reset the speedo, then your odometer will be off. I just did this swapping the clear needles from a Mark LT cluster onto my XLT, had to reset the needles a couple times
Old Jul 6, 2014 | 06:56 PM
doc11965's Avatar
Well if the rains hold out in the Morning I will give it a try
And thanks for the info..
Kevin
Old Jul 26, 2014 | 11:10 PM
doc11965's Avatar
Well I guess my eye's are bad, as I cant figure out how to get the needles off
is there a set screw, or just pull off....Thanks Kevin
Old Jul 28, 2014 | 11:09 AM
ak_cowboy's Avatar
You get a fork and gently pull straight up. they're a pressure fit and will pop loose
Old Jul 28, 2014 | 08:24 PM
doc11965's Avatar
Thanks, will give it a try tomorrow, as it will be a slow day for me...
Thanks Again
Old Aug 4, 2014 | 09:50 PM
doc11965's Avatar
Well I took off the needle, and guessed at where it should be, as of now
the speedo is only off by 4 mph, so I can live that.
thank you for your help....
Old Aug 8, 2014 | 05:54 PM
ak_cowboy's Avatar
You're welcome. I had to do it a couple times to get my tach and speedo correct. My gas gauge is a little optimistic now, but not enough to bother taking apart the dash again.
Old Aug 12, 2014 | 08:46 PM
doc11965's Avatar
I understand that for sure..
