Oil????
I've got an oil thread on here somewhere looking for it now
Here ye go ..... consensus is use the stuff the dealer tells you to
https://www.f150online.com/forums/ot...u-running.html
We are lucky that Ford has their own ... do any other car manufacturers have an oil? I have not noticed one on the shelves before.
Pick one type of oil when the truck is new and use it for the entire truck's life. Changing oil that late could cause problems. Motorcraft oil and filters work best.
^What's the basis for that? I've heard folks say that before, but I've never come up with a logical, objective reason why changing oils would do anything to a motor. I'm superstitious enough that that's something I would do, but don't know if I actually buy it.
I use Mobil 1 5w-20 and Wix filters, but not because I think Mobile 1 is going to give me any better protection or performance. I just use it in pretty much everything gasoline-powered. Paying for RP would do nothing for you (nor will a switch to any other oil), and the most likely things to happen are bad (gum up cam phasers, more oil burn, etc). Leave it be.
