westin max winch tray
Old Jun 24, 2014 | 09:40 PM
BOOMER2011's Avatar
Does any body know without a shadow of a doubt if the Westin Max Winch Tray and bull bar combo for the 06-08 f150 will fit my 2004 f150? What was the difference between those years for the front ends?
By the looks of the instructions the frame horns and mounting holes all look the same.
http://westinautomotive.com/applicat...df/75-0007.pdf
Thanks in advance.
Old Jun 25, 2014 | 12:59 PM
dbhost's Avatar
The obvious is that the bumper assembly on the 04-05 has a considerably larger lower grille opening, and rectangular fog lights.
The upper mount where it goes through the lower grille opening, may, require holes that might be different, but I suspect not. I have not seem them disassembled side by side, but I know I have seen 04-05 trucks with 06-08 front bumpers on them. I don't see why you can't make this work...
IF you want a good quality winch mount and aren't married to the concept of the bull bar, the Go Rhino I have on my truck has been top notch, although a pain in the butt to get lined up first off...
