It's easy. Remove all of the fasteners (including any in the inner door handle), and then lift UP on the door panel. Make sure you lift up and NOT OUT.
If you look on Crutchfield's website, they have downloadable directions.
Top pillars just pull off. Panel inside door handle reveals fasteners. 1 at the bottom. Pop window switch out there's an 8mm there. You need 8mm 6mm and 5.5 mm for speaker.
