07 F150 5.4 3v Cylinder Head removal
I am currently working on this truck trying to remove the cylinder head. To make a long story short, a spark plug broke while being replace on cylinder number 4. I am trying to put the engine at tdc on cylinder#1 as instructed in the Haynes manual. My problem is that when I try to rotate the engine to get to TDC, the valve in cylinder#4 is hitting the piece of the spark plug that broke off and I can't move the crank anymore. It feel s like the engine is locked up and I don't want to force the issue and end up bending a valve. Can I just take the tensioner off of the cam chain and disassemble the cam chain tensioners then pull the cam out of the cylinder head then pull the cylinder head even though I am not at TDC? If not, does anyone have any suggestions as to how I should proceed.
Thank You
Thank You
