Camshaft Position Sensor
Truck is a 2005 f150 5.4l.Truck runs fine when cold.But as soon as it warms up it has NO acceleration.I mean real bad.Has new Jasper Engine and ne rebuilt transmission.So far I have replaced Fuel Pump and filter,Coils,plugs,throttle position sensor,vct solenoids,crankshaft position sensor,Drivers side camshaft position sensor,mass airflow sensor,02 sensors, cat converters,cleaned air filter,new alternator,new starter,new battery,purge part by brake booster and I'm sure a few other things I cant rememeber right now.Im buying the other passenger side camshaft sensor today to out on.But I'm to the point of no return on this truck.Would appreciate any advice.Also checked for vacum leaks and dont appear to be anything obvious.What parts start to kick in or work once engine warms to a certain temp????Would like to limit the next new parts to this problem first.Thanks
