scantool used for misfire
I believe I'm experiencing misfire when cruising down the highway and trying to accelerate faster while putting down load on the engine. With that said, is there a way to diagnose for misfires when revving the engine while at a standstill? I have a scangauge tool attached to my obd2 plug but there are no codes. Was hoping for a diagnostic tool that showed real-time data for each cylinder (i.e. graphs & numbers). TIA
on
... is there a way to diagnose for misfires when revving the engine while at a standstill?
...but there are no codes.
These misfires usually occur due to a COP that is breaking down internally, a COP boot that is leaking high voltage to ground (carbon tracking, cracked, etc), or a failing spark plug. If you just want to repair the misfire for the time being, plan on having a plug and a COP on hand. If you want to do a full tuneup at the same time, add the other spark plugs, new boots for them, and have that one COP on hand. I will note that, on my V10, I had two COPs fail at the same time. The misfire counters will point you to the cylinder(s) of immediate concern.
THanks @projectSHO89 for your reply!
Yea, I could say these are mild misfires that I'm experiencing. By "COP" do you mean Coil Over Plug (boot)? I had changed the spark plugs back in Aug 2018 but kept pretty much everything else the same (Coil packs, boots). Prior to changing the plugs there were noticeable misfires and some ODB codes to boot. Since then these mild misfires have been noticeable lately. Are you suggesting to replace the boots or possibly the coil over packs.
on
I'm not a snob when it comes to buying COPS. I just used the inexpensive ones that RockAuto sold for around $15 each 5-6 years ago when I last had this issue. Still running fine. My philosophy is to only replaced COPS that are demonstrated to be bad. Some guys will just replace them all. I've still got factory originals still in my 01 V10 at over 180k
Ditto on the boots as glc commented. They're wear items and should be replaced with the plugs. Put a bit of dielectric grease in each boot when you install them.
