Help ! #3 Misfire
I have a 2007 f-150 5.4 I constantly and receiving a misfire code on #3 I have changed the coil x2 I have changed he plug x2 I have swapped out coil to see if misfire changed and it did not . There is a slight stumble and misfire and when I really get on the gas it misfires even more and rattles the engine. I have been to 2 tranny shops and they Both agree its the engine Can it be Catalaytic converter ? Bad connector wire ?
I have compression tested cylinder and its good, checked intake for cracks all good
I need Help !
Rob
I need Help !
Rob
Why would you be going to a transmission shop for an engine concern???
Lots of things it *might* be.
Might be a bad/fouled injector. Could easily be a mechanical concern with the base engine. Burned valve, cracked head, head gasket, etc are all on the table. A dry AND wet compression test would be valuable. A coolant check for exhaust byproducts could be useful.
Well if you CLEARLY would have read original post I did state what was done that was relevant at the time YOUR time is wasted with answers like that !
