Fuse 14 issues
Old May 8, 2020 | 11:43 AM
RyanLinthicum's Avatar
Fuse 14 issues
2006 F-150 STX 4.2 single cab, When I have fuse 14 in my speedometer doesn’t work, neither does my temp gauge, a/c compressor, and my dash lights up like crazy with multiple different lights(battery, check engine, wrench). When I plug in the scan tool it says there is an error connecting. BUT with fuse 14 out, everything except the a/c compressor works. Now that was fine for a day or so until yesterday when I would hold down the brake pedal it makes A ding all the lights come one and the temp gauge and speedo both drop to zero just like if fuse 14 is in. But the second I let off the brake it all comes back on and the lights go away. Yes I’ve plugged the scan tool up with fuse 14 out and it shows nothing. I have no check lights with the fuse out.
Fuse 14 controls-
Back-up lamp and Daytime Running
Lamps (DRL) relay coil, A/C pressure
switch, Redundant speed control
switch, Heated PCV (5.4L), Trailer
tow back-up lamps relay coil, ABS,
Reverse park aid, EC mirror
Old May 8, 2020 | 02:42 PM
joe51's Avatar
Check the ground for those items that are powered off of fuse 14. It sounds like the ground is open and the circuits are grounding back through another circuit.
