ABS and Brake Light
2004 F150 5.4L v8 3v
Brake pedal has been squeaking and almost straining, ABS has been on since I've owned the truck. Replacing the rotors and pads this weekend but wanting to know if anyone has heard squeaking in their brake system. i have bled the lines for air already. possible MC or booster? Any advice is helpful and appreciated. Thanks in advance
Are you saying both the ABS and the brake warning lights are on? Those issues need to be corrected before you can troubleshoot noises. ABS codes can be read out with higher end OBD2 scanners.
