'04 f×2 lariat code p0351 help request
Old Apr 27, 2021 | 12:09 PM
Mcripps04's Avatar
I decided to replace my original plugs at 122k after low power and random cut outs at stop lights. All plugs came out whole and replaced with motorcraft sp 546. I have a code p0351 that is not going away. I have also replaced the coil, coil end connector, rotated coils, plugs and resetting code with no change. I have checked continuity between pcm and connector with .06ohms on neg side, there isn't a short to ground. In the on position, I have 12v on pos side of connector. With a spark tester inline, I get a spark but seems week. Any one have an idea? I'm thinking pcm.
Old May 4, 2022 | 02:12 PM
wad_96's Avatar
Got an update on this, I'm in same boat? Same cylinder, even.
