starts then dies
I replaced timing chain and the works truck drove great for three days then the other day started running rough then died , now it starts on the first turn then dies after one second
\anyone ever have this?
Triton 5,4 3 valve 2007
Have you scanned for codes? More details on work done and how exactly it died the first time would help.
If no codes I would check fuel pressure first, should be schrader valve on the rail you can use to do this.
No Schrader valve on the 2004 and newer systems. It uses a FPDM instead of a FPR. You need a scanner to read out the fuel pressure PID.
That brings something up - check the backside of the FPDM and its connector for corrosion. Common issue.
