Drivers Side Power Window issue
On my driver's side power window the window goes up and down but lately it won't go up unless I hit the button several times. Im thinking this is probably an issue with the switch and not the window motor itself since it seems to eventually work, right?
Switch contacts get covered with a residue as they arc when used, there are threads and videos on cleaning them. I've done my '07's a couple times, used like 1000 grit paper or gently with a pick or knife, keep parts close, too easy to loose. Not hard, last tiine I used NO-OX-ID contact grease. https://www.f150online.com/forums/ar...ow-switch.html
