2006 no crank/ no start
2006 Ford F150 v6 4.2l manual Week ago I was driving, parked, and when I came back it wouldn't start, crank, or make any attempt. Lights work, radio works, dash worked but when turned the key just a click sound coming near the fuse box. Pushed it down a hill and pop started it, drove back home about 15 miles fine, parked on a hill so I could pop it the next day Next day pop started it and went to auto store with the engine running. When I went to drive back the engine stalled out on its own. Luckily in the parking lot i was able to push it enough to get it to start but within 2 minutes the dash turned off. Had no electronics and it stalled out again. I pushed it down a giant hill and tried releasing it in 2nd gear but no matter how many times it wouldn't pop again. I replaced the starter myself. Charged and checked the battery. Wire brushed and cleaned the terminals. Replaced the ignition coil. Even checked fuse 34 and the fuel pump module wires (saw couple of YT videos saying that can cause a no crank no start) and previous summer I did the sparkplugs. But after all of that it still only clicks when I try to start. I don't know what else to replace... does anyone have any idea at all what could stop it from starting? Not even a turn over, a cough, sputter, nothing. The lights don't dim. The radio turns off when turning the key like a normal start. The theft light doesn't blink anything abnormal. It seems like everything is good and normal but it just won't start! I've ran out of ideas and haven't the foggiest now. Thank you
Even if it is the alternator wouldn't I still be able to pop start it?
What is the EXACT source of the clicking you are hearing when you attempt to start it conventionally?
If the starter relay is CONFIRMED (not just "sounds like") to be what is clicking, then that eliminates everything that controls it. You're left with the power feed that goes through a fuse F101, through the relay (when energized), and to the starter motor where it is supposed to activate the solenoid to run the starter. Something in that path is open or the starter is bad.
Check the fuse. Crawl under there and inspect the wiring for corrosion or having rotted off the starter, that's pretty common.
After that, you'll need to make some voltage checks to see where the signal is getting lost.
I put a brand new starter in and didn't see anything wrong with the wire when I connected it. I can crawl back under and thoroughly inspect the whole line. And thank you for the fuse, I'll check that as well
Do not overlook the possibility that the replacement starter is a dud. I developed the habit years ago of having starters and alternators tested in the store before I paid for them. That has saved me several times from off-the-shelf duds.
In case anyone has followed this, I finally got my truck back from my mechanic, and the solution dumbfounded me.
My mechanic was stumped too, with power going everywhere where it needs to, but still no crank/no start.
The solution:
Corrosion on the starter mounting plate next to the transmission!! Not the wires, not the solenoid, but the mounting plate. It built up and took away the grounding from the starter!
once he found it, a scrap and a brush later, and the truck starts up no hesitation at all.
Its difficult to spot when you're crawling under laying on your back (like how I did it...) but if you have this same problem, just try to check this out.
Thank you to everyone who responded and helped me!
The solution:
Except you. You would've cost me hundreds extra more. Don't immediately suggest and say things when you don't know. 'Senior member' shame on you
Well, excuse me for trying to help. **** off. You COULD have just tested the battery and alternator to rule them out, you know. Excuse the hell out of me for forgetting to put the word MAY in.
So you installed a new starter and didn't clean the rust off the mounting surfaces..... And you get pissy with someone who is only trying to help.... Maybe you should ask for a refund for all the money you paid for advice on this forum.
