Engine misfire blower only works on high
Old Jan 28, 2021 | 08:09 PM
David Hulbert's Avatar
Electrical malfunction engine rough running wanted all to know i worked on 2007 f150 same 04 to08 there is ground wire under fuse panel passage side that was rusty connection cause all kinds of issues window heater ect check yours main double ground
Old Jan 28, 2021 | 09:46 PM
David, can you please explain a little better? I'm having trouble following what you are trying to explain.
Let's break this down:
1. What engine is in your truck?
2. It sounds like you are having a water leak some place. Do you have a wet floor board?
