- Transfer case oil change easy --cheap
- shifter kit running 35s
- 4R70W 1-2 shift clunk
- rear end question
- Flywheel for a C-6
- Got stuck.. Need Info..
- clutch return spring
- Newby Dumb Questions...
- What is the most recommended Mercon V?
- Do you have this?
- transfer case fluid?
- leaking clutch master cylinder?
- Beefing Up the Manual Trannie
- transmission damage, low clutch fluid?
- torque converter drain/refill
- Ar ethe transmissions the same for the 4.6 and the 5.4
- manual tran. fluid change???
- Short burst of Noise at 10 to 15 MPH and coasting.
- Shudder problem fixed, but now 2nd gear doesn't work right!!
- Help with MYFORD.COM
- trns drain
- Do you have a shudder/chatter problem, too?
- A question for 97 4R70w owners
- How Much Oil?
- Quakerstate 4x4 Synthetic Blend ATF?
- Trans pan magnet 'goop' (pics)
- Planetary gear explosion.
- 4r70w?????
- When pulling tranny filter off,whats with the orange o ring?
- Transmission under/over
- rear diff change question
- 4x4 stuck in 4x4low
- Removing the boot from the plug.
- Tranny shimmy (thanks)
- Anyone tried a syphon pump thru the dip tube to drain tranny?
- Cost on a 4R100
- Groan/Knocking under moderate acceleration?
- Shudder noise, 3rd to 4th.
- Harsh 1-2 Upshift
- very rough shifting
- tranny temp gauge install
- T-5 or tremec swap into 99v6 5 spd?
- 4.2 V6 w/manual tranny grinding 1/2 shift, HELP!!
- My overdrive light keeps flashing
- 5 speed/ 2-3 noise
- Need Manual Tranny maintenance how-to?
- Trans squeals on shift
- New Transmissions any time soon?
- Searching among gears
- 462 Lincoln Motor, need a standard tranny for my 85 F150
- A Question About Transmission Shudder
- Tranny Temp Guage/Transfer Case Guage??
- trannys aren't cheap!
- Hard shifting 99
- Question for Factory_Tech...
- Wolf's Head ATF
- In Need of a Tranny Cooler??
- 4r70w Shift Kit
- HOW TO: Manual Transmission Ignition Lock Lever Removal
- E4OD fluid?
- In need of help!
- 4WD question on 94 F-150
- Will mustang gt trany bolt up to a 4.2?
- Transmission Noises
- Inherient Transmissons problems with Ford
- Transmission Drain v/s Machine flush
- 2001 F150 Transmission Noise
- differential question
- speed sensor same on A/T and M/T?
- Flashing overdrive light
- Transmission vibrates from third to fourth gear.
- how many miles can you get from a A/T
- A piece of advice needed
- 35 in. Tires hurting my truck?
- Stock to 4.56 w/ Precision Gear?
- Clutch Adjustment
- speedometer zero
- vibration while decelerating
- Overdrive slip???
- speedometer failure
- 3.03 to 3.73
- Transmission Type
- Trans Rumbles
- Trans Code "U"
- Overdrive switch problems
- cooling upgrade?
- NEED HELP!! Superlift Truspeed and Tranny Harness ID
- I would never have made it as a pipe fitter
- tranny noise at re-acceleration(((
- Transmission Fluid
- Leak!!!!
- where to get shift kit ?
- Transmission ID site.
- Blowing seal
- Transmission Pan Size?!?
- First gear doesn't engage on my automatic....
- 2001 Ford F150 4x4 Problems Clutch
- Torque Converter Clutch Slipping?
- 4th gear pulls like 3rd
- going from 3.55 to 4.10
- Got Tranny / Clutch serviced, now my truck (5 spd) vibrates and shakes.
- Speedometer gear
- Changing Shift Points
- Is This Tranny Shudder ??
- 4R70W with MERCON? Is it possible?
- tranny fluid change questions
- Dakota 5 speed
- My automatic needs a clutch!
- Vibration when shifting in fourth gear.
- What kind of transmission do I have?!?!?!?!
- 5-speed manual tranny problem.
- Pan Gasket
- Torque Converter, lock...unlock!
- Is this a problem? (tranny)
- Tranny Slipping
- sloppy shifting
- Transmission Temp Guage
- Need help fast!!!!!
- RPM and gear ratio
- Trans Temp Guage
- Torque convertor and towing
- Whats my Supercrews gear ratio?
- Speedometer Gear Failure every 3 months
- aftermarket shifter good or bad idea
- Which shift setting!!!!
- Tranny ?
- gear ratios
- speedometer
- Shift or get off the ...
- 4R70W (AOD) vs. 4R100 (E4OD)
- Good Deal...
- additives
- Trans Cooler
- down shifts by itself
- Correct Speed
- Trans shifts itself out of 4wd...
- rumble-strip like vibration. Tranny?
- Factory Tech and Mobil 1 ATF
- How Do You Determine Gear Ratio?
- my E4OD and a huge headache!
- Backup light switch
- Is factory fluid synthetid
- Explorer tranny..what is wrong?
- Best manual tranny oil & diff fluid?
- Torque Converter?
- TransGo vs Baumann vs Level 10
- Clutch chatter.
- 97 F-150 Transmission fail
- Can anyone explain the advantage of Sonnex or Baumann Valves?
- What tranny do I have?
- Transmission shudder/thud and slip-yoke
- Can someone sort out confusing Mercon types?
- Have you done this?
- E4OD maintanance @ 50K miles.
- Shifting Auto. like a Manual??
- Rattling clank in reverse
- Super Duty Transmission
- Gear Ratio?
- What Do Baumann Valves Do To Improve Shifts?
- Tranny Shifting
- look what I found in my tranny????
- Tranny/tire Problems
- 4r70w or 4r100?
- What is that rubber plug on my tranny?
- Problem 4X4 engages by itself
- E4od Transmission
- Questions on 4R70W Shift Kit
- slip`s going into 2nd
- E4OD and 302?
- Trans life
- my opinion
- 4R70W Whine at 12,000 Miles - HELP
- Am I Halucinating?
- Where's my trans. fluid going?
- trans vibration
- Shift kit ideas anyone?
- Tranny Fluid
- Trans Overdrive
- Trans Help
- Not Tranny but just curious....
- 1 - 2 clunk anyone?
- Can't get into 1st gear at stop.
- A question for Factory Tech
- 4.6 5spd shifter?
- which tranny do I have?
- Transmission noise under full throttle
- B&M pan won't clear crossmember
- Got the Diablo Sport, now what (Diablo Valve body kit or what?)
- Transgo Install "Settings"?
- general question about a ford tranny.
- can i swap transmissions from an automatic to a manual?
- OD Light Blinking?? 99 5.4 Lariat
- Always looks dirty?
- transmission
- Need copy of Tailshaft TSB
- Overdrive/Convertor
- Driveline vibrations
- Factory_Tech where is thw TQ drain???
- warranty riembersment for dealer?????
- Ticking noise in 5th gear...
- what model tranny do i have?
- Tailshaft Problems, Help!
- Changed my T-Fluid/Did I miss something?
- I'm stupid...
- Transmission Problems, Look no further!!!
- Lining up drain plug with hole in torque converter.
- Average Clutch Life??
- Won't come out of second...
- New Machine Drains Clutch Packs and Torque Converter Too!!
- help me figure this out
- There's a drain plug on the Torque Converter
- Shift Kit?
- Poor transmission performance in Screw
- Trans Upgrade
- speedo twitch
- 4-High VERY tight
- Need technical advice
- Trans oil
- How much toque and HP can it take ???
- Lightning tranny on 4.6L?
- 4R70W Shift Kit
- New Tranny?
- Cost To Install TransGo Shift Kit??!!!
- Overfill
- Dipstick leak
- 82 trannie
- Help with tranny temp sender placement
- LEVEL 10 HYDRO vs TRANSGO SHIFT
- Does your 5 speed do this?
- Level 10 Hydro System
- Transmission "Thud"
- New Tranny on the way
- Calling Factory_Tech
- trans problem
- Local Ford Dealer is Clueless!!`
- Ext. Warrenty - How Much
- How-to article on changing fluid
- Can you tell by looking what tranny you have on a 2001 F150 ?
- Manual Transmission Conversion
- Need advice with tranny replacement
- Hydraulic line disconnect
- Power shifting
- Possible tranny upgrades need so answers...
- Recommend best automatic mods??!!
- 4r70w Erratic Shifting
- How Tough to rebuild E4OD
- I got Screwed! - Manual Tranny Towing Question
- 5 spd. high performance replacement
