4R70W - preventitive maintenance....
Old Sep 5, 2005 | 11:58 PM
Aaron_T's Avatar
So, I wanted to do some maintenance stuff to my truck. I have only had it less than a month (at 40,xxx miles now), but I want to make sure everything is good to go, etc.... help me get to know the truck better too.
My main question would be about the tranny.
I know shiftkits are supposed to (well depending on how they are done) help the longevity of the transmission. I believe the Factory Tech kit is one of these.
Now I don't want it spinning/slipping the tires when shifting into 2nd (I doubt it could do it going into 3rd) since there's ice and snow a good portion of the year, but I do want to help the tranny by letting it shift quicker etc...
Also, would my 01' come from Ford using Mercon V? If not, should I switch?
Oh yea, if I am at WOT, when it shifts I here a "hiss" or "howl", sort of like a quite blow off valve. This something I should be concerned about? It shifts fine, just not sure what the noise is.
Old Sep 6, 2005 | 07:26 AM
dirtyd0g's Avatar
Just like any 4r70w you want to service it every 35k at least. There likely will not be a drain plug in that converter so you will either have to install one or use a different method to drain the converter. The hiss souns is probably belt slippage on shift. Get a goodyear gatorback. That truck came factory with mercon V.
Alan
Old Sep 6, 2005 | 01:10 PM
Aaron_T's Avatar
Thanks man
