clutch issue
Old Sep 7, 2005 | 09:58 AM
Miloweb's Avatar
clutch issue
hello, newbie here, I have a 2k2 F150 4x4 with manual trans. I was wondering if anyone has had an issue with the clutch that if you let out the pedal at lower rpms it engages right away but at higher rpms (getting out of the hole fast) it seems to slip and finally grab. The clutch, pressure plate and slave cylinder have been replaced not too long ago. (because the slave cylinder froze at half pedal) Any hints, is there a way to lube the slave cylinder. I was thinking about putting a hloe in the boot and try to lube the shaft the seal the hole. Has anyone had this issue.
Thanks, Matt
Old Sep 7, 2005 | 10:21 PM
zapster's Avatar
the clutch is "slipping" at high rpm launches? ......the clutch is saving the rest of the driveline from!boom!
but the pressure plate springs could be weak also
put a centerforce kit in it if you want the "kik"
...zaP!
