Slip yoke issue
Old Sep 17, 2005 | 10:01 AM
YOMAN's Avatar
Slip yoke issue
I m sure most of you aware that 04/05 F150 has some issue with slip yoke (shudder on take off only) and there is a TSB for it.
I had a little issue with my truck FX4 04 shudder on only take off straight.
My rearend limit slip already has replaced the clutch and its all good!
I decieded try it myself, i removed driveshaft, used regular Valvoline grease and applied it and it works as smooth for approx 4 weeks then it start slowly came back....
So i ordered Teflon grease thru Ford dealer part dept that they use it for TSB and i applied it and its sad to report, it only last 17 days !
Soo do you have any suggest BEST grease that doesnt dissolve quick and best last longer ??
I havent try mobil one grease...
ANy feedback?
Thanks!
YOMAN!
Old Sep 17, 2005 | 11:12 AM
Drdexron's Avatar
I've had good luck using the Ford Teflon grease. I always clean the inside of the slip-yoke first with brake clean before applying the grease to the slip-yoke splines.
Old Sep 17, 2005 | 12:42 PM
YOMAN's Avatar
damn..how often do you apply it ? is it once or ?
.i also used telfon grease but it doesnt help at all!
I even used brake cleaner too
How much grease did you fill it in ?
Thanks!
YOMAN!
Old Sep 17, 2005 | 03:21 PM
general05's Avatar
i have a 2000 f-150 sport v-g 2wd, and at 60k i started to feel something go wrong in the rear end and it ended up to be the u-joints going south. we replaced them with greaseable one and i havent had a problem with them since. this might help u out.
Old Sep 17, 2005 | 09:32 PM
JerseyGeorge's Avatar
Thanks!
YOMAN!
Yoman,
I went through this with my 2002 F250 and that Ford crap never worked for more than two-weeks. I finally used a "marine" grade bearing grease and never had anymore problems. If that stuff can take the saltwater it can surely lubricate a truck slip-joint
Also don't go crazy with the grease or it will hydrolock and not move properly....a THIN coating is all you need!
Old Sep 19, 2005 | 08:11 PM
subford's Avatar
I have asked this before with no answer. If it is a 2WD with center carrier bearing which slip-joint are you talking about, the one on the Transmission or the one at the center carrier?
