A toughy...
Old Sep 8, 2005 | 08:57 AM
spray004's Avatar
A toughy...
I have a '98 F150 4x4 with E4OD. It was recently rebuilt and the TC was replaced (300 miles ago). The transmission works and shifts fine until I get off the interstate. I can drive around town all day and it works great, but if I drive down the interstate and exit, it starts shifting too hard. The transmission shop says that the speed sensor on the transfer case is throwing a code, they've put on a used one and a brand new one including replacing the plastic gear. The transmission is still shifting hard. I have a Superchip in it as well. Does anyone have an idea as to what could be causing this? It only happens when I drive down the Interstate and exit off, when driving around city street everything works great.
Old Sep 8, 2005 | 09:01 AM
adrianspeeder's Avatar
E4OD???
Do you mean the 4R100? 4R70w?
Adrianspeeder
Old Sep 8, 2005 | 10:59 AM
spray004's Avatar
Originally Posted by adrianspeeder
E4OD???
Adrianspeeder
E4OD, its a 10/97 buid date. I think (could be wrong) but the first 98's were E4OD's and the later builds were a different transmission.
Old Sep 9, 2005 | 01:32 PM
spray004's Avatar
Anyone?
Old Sep 10, 2005 | 11:04 AM
I'm not to familiar with the E4OD, but just an idea to try it without your superchip?
Adrianspeeder
Old Sep 10, 2005 | 08:05 PM
WVtrucker's Avatar
Could it be that the torque converter is not unlocking when getting off the interstate? Does an E4OD have a locking converter? I think it does but I am not sure. I would try it without the superchip as well. It sorta sounds like an electrical problem.
Good luck.
Old Sep 11, 2005 | 09:07 PM
spray004's Avatar
I told the shop to try it without the superchip. The torque converter is new, not rebuilt. They put a rebuilt one in, but it went out within 100 miles, so they put a new one in instead. According to the shop, their machine says its the speed sensor because the truck is actually going either 6-8 miles faster than the speed sensor is reading.
Edit: Also the wheels and tires are factory size and the ring & pinion are stock as well.
