Potential problems
Old Sep 7, 2005 | 08:17 AM
Ganners's Avatar
Potential problems
A couple of months ago i bought a 2000 F-150 with 4.6 and 4 speed auto transmission. Is there anything to look out for, trouble of any kind.
It has 62000 miles on the odometer.
Old Sep 22, 2005 | 02:42 PM
Ganners's Avatar
Hmmm
Obviously there is not many who knows the F 150 in this forum, since there is no one who can tell anything about them. But i guess it was worth a try!
Old Sep 22, 2005 | 02:46 PM
casey_1's Avatar
Change the trans fluid at least every 30K miles. If you don't you will have trans problems. Make sure to use a fluid with a MERCON V rating.
Sometimes some of us have other things to do so it takes a while to answer a question. I don't think there is a 24/7 paid person here answering questions.
Old Sep 24, 2005 | 08:34 PM
Ganners's Avatar
Thank you for your reply! I appreciate it. Of course nobody is here 24/7. But i got the response i wanted. Anyhow, i have noticed that when i drive slowly, att 15 - 20 mph for instance in rush hours, there seems to be some slack in the drive train, causing some clack-clack in stop and go traffic. I have tried to locate it, but it seems to be a combination between the transfer case and the diffrential. Is this normal and noyhing to worry about, or should it be taken care of. I still have one month of guarantee left since i bought the car.Apart from this i love this vehicle. Even if gas is 6,40 a gallon here in Norway!!
Old Sep 25, 2005 | 03:36 PM
hmustang's Avatar
I have a 2000 with a 4.6 V8 and auto trany it has 95k+ miles on it had no problems yet
Old Sep 26, 2005 | 09:18 AM
general05's Avatar
Replace the U-joints. That will stop the clacking noise, the U-joints are worn out. Replace with the ones with grease zerks makes them last longer.
Old Sep 28, 2005 | 01:40 PM
Ganners's Avatar
U joints
The u joints where replaced when i bought the truck, 1500 miles ago. I have cheked for other things, and it seems to be alot of slack in the transfer case.
Old Sep 28, 2005 | 02:39 PM
adrianspeeder's Avatar
Howdy, sorry for missing this, I didn't see it.
How exactly did you check for "a lot of slack in the transfer case"?
Do a fluid flush on the tranny if it hasn't been done yet.
Adrianspeeder
Old Sep 30, 2005 | 02:02 AM
Ganners's Avatar
Fluid flush
Adrianspeeder
Thanks for the reply
I lifted the truck up so i could turn the wheels. I vent under to look, while a friend of mine moved the wheels.
There was nothing to see in the differential, but i could move the drive shaft about 2/10 of a full turn.
What do you mean by a fluid flush!
