Hard 1-2 Upshift, O/D off Light Flashing
My 2000 f150 4.2l 4x4 has been having a hard 1-2 upshift and most of the time the od off light would flash on and off. I thought that it was the typical broken accumulator spring, but I pulled it out today and the springs were not broken. It has a white bottom spring and a brown top spring. It also has the new style steel accumulator with molded seals. Does anyone know what else could be wrong??
2001 f-150 4.6L transmission
i had similiar problem OD light was flashing, i took it to dealer, they said it was a harness failure, then dropped pan for replacement and found large metal chunks, not just the norm . they recommened replacement of trans, so here i am $3120.81 later with a replacement that has a 3yr/36,000 warranty and i still have problems with the new one, taking it back tommorrow, i recomend dropping the pan for inspection and changing fluid every 15,000
