View Full Version : Pre-1997 Models
- Blew the tranny
- Ultimate Air Intake Setup
- 1994 F250 Rear diff trouble
- Performance Module
- Selling Bessie...
- Injector????
- Donate you're going to love me! 87-91 Clears!
- Wanted to share in hopes of helping someone
- alignment not making it drive straight - terrible pull
- Buying a Bronco
- I just don't understand...gas mileage?
- Whats goin on?
- thermostat
- Power Steering, what the heck is leaking?
- Stroked 351W or BIG Block?????
- EVP Sensor vs. EGR Travel
- 5.0 headers on a 5.8?
- Are there any options for a locking tailgate for a 95?
- how do I post pix of my truck
- women drivers, no survivers
- '78 F-150 with 429
- Mods - I have made a decision
- powertrain control system, what the....
- f-100 ranger
- need front axle shafts for a 78 1/2 ton
- Got Smoked
- tune up time
- throw-out bearing
- 1.7 roller rockers
- San diego owners
- Is an 87 door glass supposed to fit the 88?
- F.i.p.k Finally Finished
- 95 chrome rear bumper
- New Pics
- 92 f150 4.9 distributor change help
- not again...
- Do pre-1997 F150's shift "hard" ???
- Help me understand my rear end
- Mustang wheels on the truck.
- 302 to 351. Is this a pain?
- MAF sensor
- Stock Wheel Size
- Cams Again
- how much can i tow with the stock bumper?
- Powder Coated My Front Bumper
- Transfer Case
- Edelbrock IAS shocks are in!
- This is what it has come down to..
- How much of a difference
- Raising the truck:
- A/c Switches From Front Air To Defrost By Itself
- hot water thottle body hose
- Brakes vs. Vacuum
- Ground wire???
- Need help
- calling Beastie seat lift question
- Anybody go with a 347?
- Shocks
- Burnout at FTW LA Chapter Meet
- Chilton's online
- Leveling Kits - Qx's
- body lift question
- Oil presure
- Ford Trucks History
- HP and Torque on the 351
- oil pan gasket ???
- Upgrading to a High volume/pressure oil pump???
- Crankcase air filter
- Serious Cruise Control Problem
- Will 3" Body Lift clear 33" tires"
- Sqeeky Leag springs
- Front Speakers for 96 p/u
- I think the ol truck is runnin rich
- Air Assist Front Coil Spings
- Trip Odometer
- Bad plug?
- obd I-II
- Camshafts
- Throttle Bore?
- Water Jacket Filler
- Dyno Numbers :)
- Places to get body panels....
- Almost There
- Radio installation Qx
- Compucam2020/powermax
- Sorry my Pre-97 buds.
- Did a Centurion edition exist for 1996 p/u???
- Brake proption valve
- Whistling brakes
- check engine light killing me
- Transfer Case Question
- Dyno time
- Severe idle surge 88 5.0
- clunk while driving???
- cat-back?
- Attn:
- Polyurethane motor and tranny mounts
- where to get oil tested???
- Y'all are always asking/wondering
- Wow how time flies
- 4x4 front axle info
- New Help Needed ( Parts Related )
- Help please
- clear corner lenses for older trucks?
- need help!!
- Saw something awesome today
- Inline 6 Idles Rough
- 1992 production #'S
- Question for Macgyver
- Wondering what I should do
- Raw Fuel Smell
- power window question
- Cowl's purpose?
- how much?
- I think i need some traction bars
- Clunk in rear end
- Fuel Filter
- 1977 F-150 Engine/Tranny ?'s
- Here is a preveiw of the new wheels and tires.
- Enigne Surging at Low RPMs
- Turbo setups
- Towing Mirrors
- Got it back together
- Hey Fella's and Fella'ets
- Day Light Running Lights
- Woah!!!!!!!!!!!
- 88 F-150 Tranny?
- What is this.....whats it do?
- Attn: PKRWUD
- "Rear-antilocks"
- I think I got ripped off
- Is this a stuck thermostat
- 92 custom f-150
- 1972 f-350 ranger xlt camper special
- my 65
- Body Question
- Rocker arms and cam, no clue what to pick??
- New Member, some newbie questions
- really dumb question
- Lug Pattern of Pre 99 f-250?
- 1988 Tranny?
- MAF conversion for 95 EFI 351??
- Gauge Pod pillar
- Ford 5.0 EFI adjustable idle spacer. Any good?
- had my codes checked today
- wahey, just checkin' in
- Sigh
- What else should I replace?
- What would be better
- Installed My Throttle Body Spacer Today...
- Need Block?
- Stupid POS!
- Help, Need Advise Quick!!
- 351
- Uuuum, sure...
- Got my pulleys in
- What should compression be?
- Need Advice with a couple of issues.
- Which Covers
- Engine cutting out
- Ignition switch stiffffffffffffff
- Fuel tank leakin
- Argh!!!!!!
- got some pulley!
- Cool!
- Bronco update and some questions.
- 302 to 514 engine swap!
- 1995 5.8 Idle Speed
- Which injectors for H.O. motor transplant?
- difficulty starting truck
- Reliability/accuracy of oil pressure gauge in '90 F150
- 4WD Conversion
- Goodbye to my 88 F150
- Anybody running an aftermarket throttle body?
- mpg
- Poor Running (Vac - ACV)
- '86 F-150, will 302 fit where my 300 was?
- More HP
- Thanks
- Question!
- Pre '99 F-350 Curb Weight...
- Attn: FORCEFD
- Well I have a dilema
- Fluctuating Oil Pressure in a 5.8L
- Speedometer calibration
- ram air intake = wow!
- 302 Died in my 93
- The best find ever
- Yo Beastie
- Well I've talked about it, but finally done it
- 86 F-150 300 6cyl Towing Capacity
- Help! My 90 f150 4x4 Mysteriously died on the way home
- no need for any other help...go to this link and look
- 4x4 for a comuter truck?
- Truck died.....AGAIN
- PCV and fuel filter switch
- Tranny done & whats next
- 300 6 power increase
- Hmm
- What would you pay for a truck like mine
- Problem with fan clutch?
- my 86 efi 302
- Bad starter relay or starter?
- Mass-Air Conversion
- Instrument Panel Swapping?
- uh oh...tranny not cooperating
- Power door lock motor
- Low Gas Mileage
- Pics of the Bronco.
- Argh...broken bolt
- 1993 4.9 Starting problem
- Clogged Cat cause crappy MPG?
- transfer case help
- Hey Guys.
- better fuel mileage with the rear tank??
- Tranny access panel
- How Do I Post A Link???
- I'm back !!
- window question
- Tranny Cooler I got
- Look at my stick.
- 95 f150 supercab length?
- M5OD help!
- radius & axle bushings
- 86 f-150 efi 302 surges...rolling idle.etc...
- It's here!
- Tranny Swap
- Rear ABS Light
- o2 sensors
- My new motor has arrived...
- Heater..thump...thump...thump
- Need some advice and input
- 1997 ford ranger
- bumper brackets for body lift
- Truck broke down
- I Need Help Bad!
- Truck sputters when warm
- Replacement Engine Opinion
- how do i remove the EGR?
- Is this great or what.
- air box question
- Got the H.O. Motor. Now what?
- help in a hurry please....heater hose
- Finally Gonna Do It
- What Gear
- 4.9L red lineb
- 89 f-150 cam question
- volt meter
- If you get bored...
- Cali emissions removal
