PDA
View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. 95 Lightning tech questions - HELP
  2. 96 f150 5.0 dies wont restart
  3. seat belt help!
  4. Anyone Done a 302 based Stroker
  5. How to test fuel pressure
  6. stalls when idle ?
  7. whats my engine?
  8. little bit of a problem
  9. Cam specs?
  10. wheres the switch for the backup lights?
  11. how can i prove that my 78 for is noncatalyst?
  12. lpg conversion?
  13. Tie Rod Problems on 86 F150 4x4
  14. What causes dieseling?
  15. low oil pressure
  16. 92 F150 5.8 Engine Codes 181 334 542
  17. 93 lift
  18. 1990 f150 passenger SIGNAL LIGHT
  19. winch bumper suggestions for '88 F-150?
  20. Wiper Control Module
  21. Visual difference between EFI & MFI?
  22. '94 "Wont Start" problem
  23. Towing Capacity
  24. New Pics
  25. Got myself a '90, have some questions
  26. Attention Beastie
  27. help w/ lifting my 95'
  28. Press brake to start or selenoid going bad?
  29. tick me off
  30. 94 F150 4.9L What Happened???
  31. Stall Speeds
  32. 87 F150 Warm/Hot Starting Problems
  33. Hitch recomendations
  34. fitting 33" tires....2" body lift work?
  35. OK...got codes got stuff..still got issues... Suggestions?
  36. 86 f150 running terrible...
  37. Speedometer Cable Part Missing ?
  38. Rebuilding '90 5.8, can I junk the smog?
  39. 94 4.9 straight 6
  40. What am I sitting on??
  41. '96 302 Won't Start When It's Wet/Damp Outside
  42. Anybody "true dueled" a '96 302?
  43. who should win
  44. where oh where has my inertia switch gone?
  45. armrest in 93 bench seat
  46. Some pictures of my truck
  47. Rough idle/cruise 93 5.0
  48. looking for pics of 95 with 33" tires
  49. Looking at a '95 4x4 ... advice?
  50. differences in the E40D
  51. hi end miss 300 inline 6
  52. Advice on 1985 F150 300I6?
  53. Tire size for stock 15x7.5 wheels
  54. Mlps
  55. Transmission shift points?
  56. Engine Temp
  57. OEM CD player for '94 F150
  58. torque / fuel ecomomy
  59. truck won't start!!!!!
  60. What is this on my motor???
  61. 2 problems: steering, bed liner
  62. im happy
  63. bumper lights
  64. If not the starter, then what?
  65. 4.9 V6 Missing and Acceleration Problems
  66. Seat Swap?
  67. Sway Bar Upside Down?
  68. stereo wiring
  69. Broken tilt on 91 f150
  70. wiring harness (HELP)
  71. Keyless Remote
  72. spark knock?
  73. 92 F150 Find!
  74. Truck weight
  75. Replacement Engine/Swaps
  76. How to get trouble codes? Switch on/off??
  77. 94 f150 heater core
  78. Swapping C6 for E4OD?????
  79. high milage 95 to tow 4500#?
  80. Driver's door
  81. truck beds
  82. pcv valve
  83. squeaky steering???
  84. Water Pump bolts wont go back in
  85. Rear window motor on Bonco
  86. Wont come out of park?
  87. No Keyless Entry
  88. Biggest Lift and Tires
  89. 1996 F-150 with slight stutter at highway speeds
  90. leaking fuel tank
  91. engine noise, is this normal?
  92. safari light bar
  93. towing a 3 horse trailer
  94. 95 F150 Performance?
  95. My great fun 91!!
  96. What's your problem???
  97. extend cab on regular cab frame
  98. 91 f150 door panel removal???
  99. Strong coolant smell?!?!?!?
  100. 6-8 Mpg. Help!
  101. Thoughts on high mileage '90 F250 5.8 purchase
  102. A Good Deal, Or Not....
  103. 1987 brake problems
  104. Header recommendations
  105. Oil in the Air filter Box
  106. 1994 F 150 Parking Break Cable
  107. Spark Knock
  108. 05 engine in 86 feasible?
  109. 1990 audio system
  110. Newbie here
  111. what heaers for GT-40p
  112. 4.9l Starter
  113. Finally!
  114. Ack... no start and no codes
  115. Ignition Cylinder
  116. overdrive button came off
  117. location of oil pressure sensor on 1987 F150 5.0
  118. How Much Is My 94 4x4 XLT Worth?
  119. Dual Tank Selector Value
  120. 95 F150 2wd lift help please
  121. lifting the front end on my 94
  122. Code 538 Help?
  123. Tach in 80-86?
  124. Bigger Radiator with a 4.9 Strait 6??
  125. '88 F150 I-6 to 351 swap, what do I need?
  126. fuel pressure
  127. Just bought my first truck! Many noob questions inside.
  128. how big of tires u got??
  129. 87 f150 problems continue
  130. is the A/C really worth fixing?
  131. Johnny Unitas' personal 1986 F150!!
  132. A/C Low Side Service Port????
  133. Long tube Headers 95 150
  134. Ignition timing procedure 96 f150
  135. wants to stall/loses power on accel
  136. 93 f150 gauge question
  137. loud winding noise when starting truck
  138. Speedometer Gear(the one in the T-case)
  139. what is the best pre 97 f150?
  140. Fuel mileage on 1980 F100 with 4.9 six-cylinder
  141. Serpentine Belt
  142. Fuel Injected or Fuel Injection? HELP!
  143. '90 F-150
  144. Whats ringing my bell/chime
  145. Rust on 95' F150
  146. Best way to boost power??
  147. Starter question???
  148. installing a starter
  149. Switching From Carb to EFI
  150. 91 f150 clunking noise???
  151. 5.0 truck setup
  152. Fuel Filter Removal
  153. 1996 Ford F150 idle problem
  154. too cold?
  155. Quick Question, Help
  156. What sensors on a Transfer Case on a 89 F250?
  157. Newbie with a ? on a 93 5.0
  158. CEL or SES on '94 F150?
  159. 1990 Chevy camper shell on 95 F-150?
  160. oil pump in a 302
  161. Combination Manifold
  162. Hiya!
  163. soft brake pedal
  164. 1994 Questions (VSS and fuel pump) ATTENTION PKRWUD
  165. Mulitiple problems
  166. cold air
  167. Front Gas Tank Leaks (1994 F-150)
  168. Fixing up used '95 F150
  169. eec 122 - TPS voltage low
  170. Stuck Auto Hub
  171. Trans slipping when hot
  172. Newbie 4x4 Questions
  173. What should I offer this guy?!
  174. I6 wierd problems
  175. ebay resistor
  176. Cats: Necessarry?
  177. back fire on idle
  178. 89 f150 exhaust question
  179. Help for the Ignorant!
  180. Hello... noobie here
  181. Auto trans to Manual
  182. Full Restoration
  183. Won't Start - Ignition Switch?
  184. steering getting loose, shimmy at 30mph
  185. manual tranny lube - What do you use?
  186. Daystar leveling kit
  187. '89 F-150 Needs help bad.
  188. pics of my truck
  189. Thinking of buying a 96 & older F-150 Have?s
  190. 96 rough idle, bad milage
  191. Fixed Fuel Filter.... what next?
  192. ignition locked..
  193. need help will not turn over
  194. o2 Sensor?
  195. underdrive pulley effects on tranny
  196. '96 F150 Cam Replacement
  197. Hi! New member with 90 F150 needs tech help
  198. Replaced oil pump, still having problems
  199. Engine Swap
  200. Header and exhuast manifold, will it hurt
  201. pros and cons of my truck
  202. 4x4 engagement with warn hubs?
  203. Breather Filter
  204. starter solenoid?
  205. Forward fuel tank
  206. Anyone ever switch their tailgates?
  207. rear brake shoes, 96 f150
  208. 1988 F-150 I-6 300 EFI stalling/cutting out
  209. 94 302 Engine:16 gallons=200 to the tank!
  210. Strange Sputter Sputter
  211. Timing
  212. 87 f150 stalling
  213. 1987 horn replacement???
  214. 94 F150 wiper problem
  215. RPM's do not drop while shifting manual tranny...
  216. Packages...
  217. '86 F150 302 EFI, dying when engine warms up
  218. emblem
  219. 93 f150 5.0 stalls in reverse mostly
  220. Interior parts, where can I buy?
  221. 87 f-150 Starter
  222. Whackyass Problem on a 1982
  223. '95 F150 tire size/leveling coils
  224. Starter probs on 96 F150
  225. 95 XL4.9 I6 2wd newbie
  226. rear end gears
  227. Old Heavy Truck Info
  228. 91 F150 just died
  229. swapping rear ends
  230. Which transfer case would you upgrade to?
  231. Brake hardline size?
  232. Can't find my Canister Purge solenoid!
  233. HELP! having trouble removing upper intake manifold on 88 f150 302efi
  234. 1988 F250 - bad tank selector?
  235. Power steering pump problem?
  236. codes
  237. '94 f-150 clutch issues
  238. Boss 300??
  239. loosing oil, No Oil on ground and No smoke out exhaust???
  240. Center Seat/Flip Up Console replacements?
  241. Dropping my fuel tank
  242. need help
  243. Upgrading steering box and P/S pump
  244. aftermarket for 4.9L I6
  245. I want to bag my 75!
  246. 1995 351W same as 1992 351W?
  247. 87 f-150 squeaking noise
  248. which 351 is in my '90 Bronco?
  249. Anybody using an inline fuel pump?
  250. well, let me try it here
