View Full Version : Pre-1997 Models
- Swapping Trannies.
- 5.8L Engine Timing Problem
- 2wdf150 popping/noise from left front
- power steering problem
- nice 1953 F-100
- Adding Power Mirrors to my 1995
- reading trouble codes
- No start
- fuel pressure 0psi with key on 89 f150
- MAF Conversion Help!!!
- '89 6 cylinder no start
- Truck misses when warm
- brakes
- Piston To Valve Clearance (Max Lift)
- Exhaust system 1993 F150
- ford f-150 1989 pickup truck
- dodge ram 20's on an f150
- GT40P heads & smog equipment
- 92 F-150 tranny swap
- Strange coolant leak...freeze plug?
- EGR- Stumbling
- Radiator support replacement
- Rear Main Seal or Pan Gasket?
- Fuel System Requirements?
- bronco e40d got hot and puked fluid
- OBD 1 port on 1989 f250 ?
- Dual Tank Switch Valves
- x
- 94 6-banger engine replacement options..
- Proud of my six-popper!
- E4OD Floor Shifter?
- Newbie Here. Please Help. OD Button Wont work.
- headers
- 80-86 Front End on 87-91?
- Need some parts...
- Want to make my 88 ford-F150 look and sound AWESOME!!
- Cut Fuel Consumption By Half!!! Tried And True!
- Stepside Beds?
- Newbie here....
- Fuel Filter Problems!!!HELP!!!
- tailgate removal
- how many o2 sensors on 1994 5.8?
- failing O2 sensors
- newbie with ? Hi everyone, i have a code 173
- Matt Sharp
- A few Photos
- Battery light on, now not starting?
- Ignition Woes?!?!
- Advice on buying a pickup for towing a car/trailer.
- '92 full size Bronco side marker lights
- 5.0 1993 F150, running wery rich
- Buying Used
- Lift kits and tires?
- Finally done after four years...
- power door lock actuator motors
- side gapping plugs...reduce gap?
- Christmas in October! Lots of new parts!
- Oil Pan Removal ?
- koeo code
- Bad Day for my 92 F150
- '95 F150 - Replacing leaf spring insulators
- Code 311 and 411
- Ignition Upgrade Time!
- Pkrwud
- Diagnostic Trouble Code 556
- 1993 suspension lift components?
- Instrument cluster swap - new question
- Exhaust & Intake Comments, Questions
- 1987 F-150 302 (5L) dies cold, runs rough
- disfunctional fuel gauge
- Knock Sensor
- Quick question about Ford Mass-air kit?
- 95 f150 super cab towing specs
- cooling system question
- One for the experts...
- 95 F150 - How to disable the Airbag
- speedo broken !?
- fuel system
- Starter Problems
- 1996 F150XL I6/Auto 4X4 opinions please
- No Oil Pressure
- my beater 88' .. help !
- 1991 F150 Starting Problem
- propane snorter?
- 1989 F150 Project
- Power Problems w/my 1986 F150
- EGR Valve Location
- stang motor into F150 swap
- Timing Marks
- 92 "nite" f150
- Tranny hesitation
- '88 help needed
- Vacuum Diagram
- changing positive cable on '92
- FIPK-Not to beat a dead horse
- suspension lift
- More Power
- Perhaps the most mysterious Engine problem ever! lol
- slow cranking
- stock 5 liter mustang headers on a 96 5.0 f 150?
- 1996 ford f-150 lights reminder bells
- remove AC- got my reasons right?
- test
- "90 F-no oil pressure
- Any RC SWB f150 460 owners at this site?
- 1989 F-150 5.8l
- steering gearbox
- Perfomance parts catalogs for 94 F series?
- Oil Pan Replacement / Questions
- Factory Wheel Type Vote In
- Thinking About a Soft Bed Cover...
- VIN help
- Front End
- Fuel Pressure Release
- Wont start after being towed
- Which AC for upgrade?
- Audio 95-96 f150
- Bucking F150
- Towing question - need quick info
- Brake lights! Please help.
- What speedo gear
- Different Starting Problems 95 5.8L
- 1996 5.0 f150 info?
- Driver side window wont go up
- 81 F150 water pump / fan removal
- 95 302 Surges stumbles and dies at idle
- 87 150 problems
- Frame Question
- motor mount stands
- A Farewell...
- 95 F150 idle surges during warm up
- NEED part number for master cylinder
- finally got my first f 150
- High idle and dieseling
- how to get to the turn signal/parking light bulbs?!
- electric window problems
- new member here and some pic's of my truck
- Howdy All!
- 1990 f150 for sale in jersey
- Which direction to go for exhaust on 302
- Which doors will fit?
- Starter on 1990 5.8l problem.
- Rusting Oil Pan
- Door Problems
- Cluster change Question.
- Diff Rebuild question
- new interior : updated link (this should work now)
- 86 ford f150 fuel sending unit
- let me know what you think of my new interior
- No Spark
- Over heating at high speeds
- Mustang Motor in 96 F150
- Looking For Help
- A/C System stalls engine
- mods for an 87 4.9liter
- Fule Gauge Bobs UP AND DOWN
- Wheels and Tires
- rear seat 86 extended cab
- Framecracks
- hydraulic clutch...slave cylinder appears to be rocking
- fuel pumps
- locating PCV valve on old model f-150
- hoods
- cold start on 86 ford
- gas mileage in a 1990-1998 F250 diesel 4x4
- 96' Tune up time..need opinions
- Need help decoding VIN #
- Coolant Capacity
- what year bed is interchangeable with 84 f150
- only heating/no cooling
- Intermittant Idle
- Injectors/mass air
- Squeel when turning
- 1991 F150 5.0 to a 5.8
- Temperature fluxuation(sp)
- i need pics
- pics of my truck:let me know wut you think
- FIPK & Cat Back Help
- Let me know what you think of my truck
- Clutch Problems
- idle problems
- Used, Want to buy what is good year ?
- Mass air conversion on E4OD trans?
- Left Power Window is Dead
- 4.9 Liter Milage
- Starter Stays on
- Cab lights
- F-150 VIN on chassis
- 93 F-150 Radio Replacement
- '95 F150 Power Steering Leak.. Help!
- oxygen sensor
- Can Start Truck W/O Key!
- Tank swap 83 on 86 truck
- Interested in a set of full length running boards?
- Stumbling, hesitation, but no check engine light.
- Tailgate Hinges for 1989 F-250 8 Feet Bed
- AC Smells and is Not Cooling
- 1987 F150 302 - Wont start, fuel selector valve?
- 93 F150 wont start most of the time
- My Truck Starts But Dies After A Couple Seconds
- Edelbrock performer truck intake?
- fuel pump - rear works, front doesn't
- Safari roof rack
- hand/foot brake light
- Perfomance mods for 85 302???
- Bed Sag
- Same 'ol problem - cold start trouble
- What can make the timing jump around 6 degrees????
- Eddie Bauer or not???
- Head Bolts
- Building a light bar
- Gas mileage?
- selling my truck check it out
- 1986 F150 E.f.i 5.0 Dies
- '86 F150 4x4 Fender Emblems
- '86 EFI running like poo
- 1993 f-150 springs
- A/C Clutch Question
- Max A/C - Norm A/C
- Gas tank Straps
- Turn signal gone
- points ignition help!
- muh 96
- 1979 Ford F150 Ranger....
- Busted axle
- Tranmission Problems
- 1994 F150 5.0 "Ping and Buck"
- Electronic Ignition Module
- 83 side mount fuel tank in '86?
- Engine Swap
- low idle (also posted in engines)
- 1979 F-150 4x4 Stepside
- switching to mustang computer HELP!
- 4x4 light flickers on and off?
- 460 air intake tube on f150?
- Black Flakes in Oil
- Pretty 1988 Lariat Dead as Elvis
- 1987 Power Windows And Door Locks
- Fan damaging the radiator
- Looking for Pre 86 F150 4x4
- fuel pump problem/question
- 94 F-150 4x2 2"body lift
- stuck in park!
- quites and stalls out
- Transmission swap in a '81 f-150
- Wipers Only Operate In Fast Speed
- Question
- Performance upgrades
- Installing 1994 (or pre-1998?) DRL
