- Check Engine Light
- Opinions on '85 F150 mods
- MSD ignition
- battered bed replacement?
- noise from belt
- Engine options?
- Need opinions.....3:55 or 3:73 gears ?
- Motors To Sell
- Noise in Cab - 1990 4x4 Ext.cab
- Vin Numbers
- Headers on & Fail Smog test
- smoke headlight covers for sale
- 9 inch rear in 92 F-150
- '85 F-150 302 fuel filter
- Air Injection Troubles
- Damn fuel filter!!!!!!!!
- which engine
- Horse Trailer Towing
- '73 to 79 Cab specs question 2
- Help me find a fiberglass tailgate
- what is the bolt patern on a 1970 f100?
- LEVELING CAB AND BED
- "Run-Rite" Fuel system cleaner>>>>
- 94 Dash
- '96 F150 Performance
- 300-351
- What size alternator on an '96 F-350 4x4 Diesel?
- Jacobs Ultra-Team Pack or MSD
- 94 F150 4x4 front suspension hop?
- Who has done rear main seal on 5spd F150?
- Idle adjustment
- '73 to '79 Cab spec's
- Should I buy? high mileage 92 xlt lariat?
- xlt?
- haedlights
- 1985 F150 5.0l EFI (Hello Mike Troyer)
- 1980 to 1986 lowering kits?
- Need A '81 Or Older Truck
- where to buy accessories?
- 86 F150 EFI problems
- 5.0L 302 power
- Help! Wandering F150
- PTC computer
- Power Upgrades
- Air Bag Code 41
- '79 F-100 lowering
- Install A/C in 1987 F-150
- no cruise;speedo;odometer
- 351 Windsor Motor
- Looking For second-hand Engine
- NEED MORE POWER
- Possible 300 I6 power upgrades
- lift the front
- 4.6 302 power
- 1996 Year Model
- Hard Shifting 2-3 When Warm
- Setting timing on a '92 5.0 EFI
- Where to buy a rollpan & which one
- 92 F-150 302 to 351 swap
- '93 F150 Brake Lines
- 91 valve covers
- 302 idle problems
- Hi guys I'm new here so let me introduce mi self!
- My Dad's lookin to buy an F250 (94-97)
- Spiral thing behind steering wheel
- Smog Plumbing on an 83 4.9L 6 cyl.
- broken bolt..HELP!!
- Clutch R&R, now idle is off
- '91 302 Rebuild vs Lifter Replacement
- Spedometer
- Pinion nut overtightened at factory?
- performance parts for 300 4.9L I6
- 95 Mass Air...
- 1995 F150 8.8 axle - 28 or 31 splines?
- 95 Exhaust
- Where to put that subwoofer??
- '96 Towing Capacity
- EGR VALVE
- Two More Questions
- B&M shiftplus
- Anyone have a oil leak in '92-'96 5.8's?
- taller springs or boby lift?
- Mass Air Conversion for 94' 5.0
- 4.9L Missing
- Taking off the door panels with roll up windows?
- 250+brighter reverse lights
- Top Speed
- 100k Tuneup
- Rear sending unit problems
- FYI, finished replacing Auto hubs
- Brakes - Larger or Different ???
- I6 Dual Exhaust
- Check this out
- 1990 accuator help?
- Any more 1980 to '86 Stepside 4x4's out there?
- TYPO it's a 1980 to '86!!!!
- 1908 to "86 Tailgate
- Axle Gear Ratio Question?
- stalling
- IFS Axle Swap
- '86 F150 stock height
- hey jetter
- Converting electric 4x4 shift to manual
- Backfire!! Engine Troubles.
- Diagnose this one please.
- What's the deal with tire sizes?
- How do I tell if truck has tow package?
- 302 to 460
- Help! Coolant coming out tail pipe!
- Lots of questions...
- cruise control troubles
- Another Clutch Problem
- Replacement Engines
- '93' 4.9 6cyl smell gas & won't start when cold outside after sitting overnight
- Clutch/Starter Safety Switch
- 95 F-150 I6 vs. 351
- Oil system problem/question
- '94 F-150 Irratic Idle
- I have an '89 F-150 and need some help....
- vin# info can i find out certain things by the vin#
- Temperature Guage Intermittant
- Should i buy F-150-please help.
- Factory Cup Holder for 1995 F-150 Bench
- Radiator Stop Leak?
- Power Lumbar
- 33" tires and gearing
- Which truck should I get?
- Awning/canopy for 1990 F150
- valve cover gaskets
- vacuum diagram for 79 f-150
- Heater Question
- Fuel Pump Replacement
- cruise control
- Removing front fuel tank. How to cap lines?
- tank selector or check valve?
- Clutch Problem
- bad wheel shimmy on left side of truck
- Alternator Gauge
- 33" Tires on a non-lifted F-150???
- Need an insignificant dash part. Anyone with a beater truck or wrecked truck?
- Increasing Rim Sizes
- Shift on the Fly problems
- my 95 ext cab 4x4 brothers out there
- Is my mechanic ripping me off?
- What should be my next Straight 6 Modification?
- bunch a newbie questions
- rear end
- Dashboard "FALLING OFF"
- I-6 Exhaust Recomendations
- Frame spec's
- Stock muffler and tailpipe
- Battery Killing Glove Box Light
- Stock exhaust
- '86 F150 Needs Carb Rebuilt
- '92 F150
- what trans can i use
- Those guys are kidding, right?
- clutch squeak
- mass air conversion
- Burnouts?
- 88 5.8L Fuel Pump Relay
- Engine cutting out on 95 4.9 I-6 during acceleration
- My bagged project truck :-)
- Sputtering
- Can't thank this board enough!!
- Performance Parts for 96 5.0
- post for jimbello
- 95 F150 Steering ratio
- Fuel Filter Warning
- I need your HELP!
- Flashing Airbag Light (5-4 or 4-5 code)
- wires
- Idle Knock
- Suggestions for new shocks??
- Getting codes from '95
- I need opinions - FAST!!!!!!! LOL!
- opinions
- Differences between 95 trucks with mass air flow sensors and those without???
- One last question: where can I get a service manual at a decent price?
- How do you look up older pre-1997 postings?
- test message...disregard
- How to replace fuel filter on 95 5.8 litre?/ couple other questions
- temp gauge out/ loose rivets on the crossmember a problem according to Ford!!!
- Upper & Lower Hoses
- How long should it take to replace fuel pumps?
- Check engine light reset
- Need your help.....
- Where can I get a decent tire cover for my Bronco?
- Tranny slipping around 40-45mph??
- dual exhuast
- HELP!!!
- transmission!
- check out this truck
- codes
- backfire valve
- fuel pressure drop
- Changed gears and speedo hasn't changed
- '93 restoration
- Underdrive pulleys and Superchips...
- engine hp
- Anyone ever have their dashboard break?
- Drive train noise
- 1991 F-150 4.9 Missing at 35mph, HELP
- Gearing upgrades
- hypertech chip for sale
- 1991ish Diesels
- '96 F350 is making a 'beep' sound from dash area???
- ....Goodbye....
- aluminum cleaner
- High mileage F-150s
- problems with in-line 6cyl 300ci engine
- Fastest 0-60 times (auto)
- Whats the maitainance schedule for the E4OD?
- Aftermarket Keyless Entry?
- Radiators
- Pinging 91 5.0
- Conversion Complete
- Chipped pre-97s
- Temp Gauge Gone Crazy
- Changing Gear Ratios
- SD to MASS coverson, at the end of my rope
- 88 C6
- HP difference on 90's and 95's....
- ECM/EEC-IV
- Need a factory steering wheel cover for a 94'
- New here...question about 300 inline 6
- 96 gas mileage
- Swapping Noses
- '95 F150 302...2 Cats/true dual exhaust?
- 1953 F-100
- Worried...
- '95 Supercab Special VS Supercab XL???
- Hp/Torque ratings for '95 F150 302 V-8.
- lean O2 sensor code.
- What should I be shopping for?
- Broke Cat?
- A/C compressor kicks on/off constantly
- Vacuum Schematic
- question about the EEC-IV in the ford trucks
- How many miles on your truck?
- How do I find out about my truck/egr problem
- 4x2 Lift?
- Hope for alot more
- converting a SD to MASS
- Bad News...
- Question abt VIN decoder
- Sparkplugs?
