cruise control troubles
Old Jan 2, 2001 | 01:47 PM
chefbill's Avatar
Angry cruise control troubles
My cruise has not worked for the longest time..horn is fine,no check lights on..????? sure would like it back..any ideas guys??
95 f150 ext cab 4x4 orp
163,000+ miles 351
straight pipes (still not loud enough)
splitfire plugs
performance wires
31x10.50x15 grabbers
rough country shocks
tinted windows
ranch hand bumper
custom front bumper
100w offroad lights
crome bed rails
autovox alarm
k&n kit coming
nerf coming
headers,pipes coming
BAD BOYS BAD TOYS
Old Jan 2, 2001 | 06:22 PM
Fordman302's Avatar
Wink
I had the same problem when i was running straight pipes on my '92 F-150. Not enough beackpressure to run the cruise, hooked up glass packs an solved my problem.
Old Jan 3, 2001 | 08:47 AM
chefbill's Avatar
Question
No cruise before straight pipes.
163,000+ miles 351
splitfire plugs
performance wires
tinted windows
ranch hand bumper
custom front bumper
100w offroad lights
crome bed rails
autovox alarm
k&n kit coming
nerf coming
BAD BOYS BAD TOYS
Old Jan 4, 2001 | 10:31 PM
Granpa's Avatar
Post
chefbill, I think you have an all electric cruise control. Servo and amp are in one unit on driver fender, no vac hoses, only wires and throttle pull cable. Do you have a stick or auto trans? Brake lights work? You said the Horn works, good. And no ABS light remaining on after startup, no ABS troublecode blinking away, good. Fuses good? Do you have a digital voltmeter and know how to use it? Tough to troubleshoot this without one.
[This message has been edited by Granpa (edited 01-04-2001).]
Old Jan 8, 2001 | 09:12 AM
chefbill's Avatar
Question
I have a auto. trans.,and you are right about the type of cruise control.Fuses are good,wires and cable on unit are fine, dont have volt meter.Is there a relay or such which I can just replace and see if that works?
