Anyone ever have their dashboard break?
There is a mounting point all the way on the right, you can only see it if you take off the kickpanel. The plastic mount broke, and now my dashboard squeaks. My dad's '93 F-150 has 140,000 miles and a solid dash. This happen to anyone else?
1999 Nighthawk Black Prelude Type SH
1992 Ford F-150 4x2 Long Bed
This is comman, your dealer can fix it. I had my local mechanic make a bracket before I found out ford had a fix.
1995 Ford Bronco Eddie Bauer. 351 V-8, 4 inch Pro-Comp suspension lift, K&N Filtercharger® FIPK, Dynomax, 32x11.50 Dunlops, Manik front/rear brush guards.
Yes i have had this happen on my 94. I was changing the fuel filter for the first time and had to release the presure switch and as I removed the kickpannel I heard the pice fall. i put a bracket under it to support it.
