PDA
View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40
  1. anybody gone from power windows to manual?
  2. Billet Steps For 92-95 Flaresides
  3. cross camber question
  4. 4.10s and LS are in!
  5. Bad gas mileage with my 94?
  6. Street Scene Rollpan?
  7. More 1/4 times!!!
  8. Need help with Wiring
  9. E Fans
  10. What would get me closest to stock?
  11. vin decoder for 94 f350
  12. '89 Lariat Seat Rattle
  13. '91 4.9 Hesitation on Exceleration
  14. lowering shackles?
  15. No Fuel Pumps during Starter Crank
  16. Project update
  17. smog pump--- shorter belt and bypass??
  18. 1990 F150 Electric Window Problem
  19. New Rear Window for '92 F-150
  20. v6 4.2L VS 4.9L I-6
  21. I-Beam question
  22. Header gasket leaking
  23. PLEASE HELP! Will this work???
  24. Diesel question
  25. Need to find an alternator...
  26. chip and pullies on the way
  27. '96, '97 460's
  28. Changing the Fuel Injectors on a 94 with the 300 Inline 6...
  29. I gotta few questions....
  30. New Here
  31. Donate54 where are you?
  32. Hey I'm new here
  33. 96 300 6cyl belching fuel under hood
  34. New Exhaust... Check it Out!
  35. Oil Pan Gasket
  36. '91 4.9L 154K - Motor Oil
  37. Advice on Gear Swap...
  38. '91 F150 4.9L Stalling idle when first cranked
  39. '86 5.0L running rough
  40. Injector resistance, is there a difference?
  41. pwer steering gearbox
  42. clutch replacement
  43. new exhaust problems????
  44. Cams ????
  45. 89 302 Missing Under Acceleration
  46. lug pattern
  47. wet okole seat covers
  48. Code Reader, HELP!!!
  49. Difference between 302 & 351 exhaust...
  50. Fuel problem
  51. Some "in the process" picture
  52. Attn people in the salt states...Save your Fender!
  53. stupid ABS light!
  54. Silly question about rear diff. oil...
  55. Stupid radiator!
  56. surging and bogging during heavy rain
  57. headed to the lake tomorrow chris
  58. Question about Troyer Performance electric fans....
  59. thanks Sprocket X
  60. Question
  61. Got my headers....
  62. Starting problem when HOT.
  63. DAMMIT Macgyver!!!
  64. Replacing the preheater....
  65. Bbk Headers
  66. putting in a chip
  67. Yet another exhaust question
  68. Some quick questions...
  69. vapor lock
  70. New pics
  71. Header Options For 1996 F-150 w/ 5.8L
  72. gear install
  73. can I block off rear tank lines?
  74. In the 16s
  75. Bought some headers
  76. 1995 F-150 headlamp assembly replacement
  77. Bad Day For Me
  78. 1989 f250 fuel gauge/sender (weird)
  79. Temperature Gauge
  80. Check Engine light @ 4000...
  81. 1994 F150 cuts out @80 MPH
  82. That Bronco I was talking about
  83. 300 6 cyl performance modifications???
  84. Modified Air Intake question
  85. 94 Bronco problems, need help
  86. Brake pads...
  87. Thank You
  88. Rear Disc Brake Conversion...
  89. Well, the 89's finally lifted 6"
  90. went drag racing
  91. rear tank question on 95 f150
  92. How many quarts? (M5OD)
  93. How many quarts?
  94. Torque converter & gas mileage
  95. Gears are on the way!
  96. Upgrade 1984 F150 300 six
  97. 1994 f150 stalls when on gas
  98. broken bolts
  99. 94 4.9L Running Hot...where to start
  100. 2x4 To A 4x4 Ttb
  101. Headers
  102. Wheel Alignment
  103. I didn't go ricer, did I???
  104. Increasing fuel pressure,Richer/Leaner?
  105. 5.0L Engine oil pan capacity?
  106. Changing M5OD fluid
  107. Removing the A/C
  108. Help with the truck:
  109. Wanted: 87 lockout hub knob
  110. 1987 F150 4X4 problems: locking hub, duel tanks, sending units.
  111. '95 Dana 44 TTB bearing torque
  112. Cowl induction hood
  113. 6" Lift with Dana 44 TTB....
  114. Master Cylinder/brake valve....
  115. Alternator upgrade,Which brand????
  116. this is easier than my last thread!!!
  117. Airbag flashing code 4-5
  118. gearing questions
  119. Electric Fan help
  120. Which spark plugs?
  121. Airbag Code 2-3 or 3-2
  122. Happy Happy Happy
  123. Upper actuator & drive gear
  124. Been wantin a Bronco 4x4
  125. A few NEW pics.
  126. Sorry
  127. heads swapped but wont fire??
  128. what do you guys think?
  129. fuel pump or something elese.
  130. Fuel Mileage
  131. pre '97 headlights...
  132. Oil Leaking..Somewhere
  133. Re-Did my intakes
  134. starting problem
  135. Got some new stuff
  136. Free to a good home!
  137. Help
  138. Wooooo!
  139. wiring diagram?
  140. tire pressure
  141. I didn't get the cam, but I did get a...
  142. Help Me Choose Gears For 35's
  143. '95 alien automatic hubs... help!
  144. Ouch
  145. What to do next
  146. Finally doin the heads!!!
  147. Need help with a 302 buildup
  148. Just ordered Electric fans
  149. I want a Bronco now!
  150. My truck
  151. Guys....
  152. 92 Inline -6 Starter Interchangeability
  153. Just shoot me..help
  154. 33x10.50 bfg's
  155. Valve cover from a 85 to a 96 4.9L
  156. ac delco pump in ford
  157. fuel pump replacement
  158. New Exhaust
  159. good deal or not
  160. I think my air pump is going
  161. mechanical temp gauge install
  162. Fuel Pump Stays Running
  163. Anybody know what this is?
  164. in tank fuel pump problem
  165. Need Help !
  166. 93-95 ford lightning air intake system
  167. 1991 F150 Loss of Power
  168. Fuel injectors
  169. 95 XLT 4x4 For Sale- Kansas
  170. Looking for A/C work input
  171. Slight problems
  172. code ?
  173. Forged
  174. ventilation---no air coming through vents
  175. Picked up an old F150, have questions
  176. clear turn signal lights 87-91
  177. No fire going to coil
  178. sold truck
  179. 1988 bronco running problems??
  180. The lift is underway!
  181. Anyone running a Crane "Truck-Power" cam?
  182. Where to put o2 sensor?
  183. Performance Products
  184. difference between 87-96 302 and 351
  185. 390 MPFI-----possible??
  186. 96 throttle body leak?
  187. Max hp with speed density?
  188. Happy Birthday Sprocket!!!
  189. 5.0L Muffler question. Urgent!
  190. took my truck swimming
  191. Specifications
  192. 360 4 barrell problems
  193. Changing front end parts
  194. emissions and cat converters
  195. oem ford parts cheap
  196. Best place to buy a winch for a trailer?
  197. Gears are Awesome!!!
  198. Truck died..fuel pump?
  199. Where can I get some brake lines.
  200. 92 f150 possible ignition problems
  201. Problem with Brakes
  202. Side gapping plug's (Chris)
  203. Would Like to do Tune up for '96 F150
  204. Lifting my truck!
  205. 19 lbs Fuel Injector Question ...
  206. HUG2 Computer code
  207. Trans gear ratios?
  208. Switching to 1.7 roller rockers
  209. Top End Speed
  210. Clunking
  211. So much.....
  212. Just ordered some more parts!
  213. Gear Q
  214. '90 4x4 center caps
  215. "high" low idle
  216. anyone who knows anything about the M5OD please read
  217. need some quick tire/rim help
  218. Code 14/19 14/22.. computer going bad?
  219. Highflow Cat's for a '96 4.9L
  220. DRL Removal.
  221. Engine Miss
  222. Hey all, new to the F150 Online boards
  223. Went to the 1/4 mile
  224. does anybody know?
  225. 96 Bronco
  226. Unknown Sensor?
  227. Temp Swings Revisited
  228. Gears !!!!!!!
  229. Goodbye
  230. 4.9 rocker arms
  231. shock suggestions
  232. damn water pump?????
  233. rotted out radiator support???
  234. Heat!
  235. Installed Homemade FIPK!!
  236. Homemade Code Reader
  237. Mods need opinions
  238. Where can I get a gas tank?
  239. Clutch/Transmission
  240. DESKTOP DYNO 2000 Engine Analyzing Software
  241. Lifting and Towing
  242. I sold it...
  243. Coil Spring Code Needed
  244. Motor plates
  245. Need a 4.0 v6 rebuild!
  246. Leaking Intake
  247. Did a little off roading :)
  248. Champion Vs. Bosch
  249. Engine Swap
  250. Got a sweet E-Bay deal
