I gotta few questions....
I have a 94 F-150 5.0L with a 4 speed automatic. I'm just curious as to what kinda power/torque I should be making, and what times I could expect to see in the 1/4. Oh yea, and the weight of my truck. It'd be greatly appreciated if you could answer these, as I dont have alot of time to search for them. Thanks.
94 F-150 5.0 (302), 2WD, Reg. Cab, short box, Auto.
Mods:
K&N Drop in filter
Short tube headers (Summit brand)
2.75" "dual" exhaust w/o mufflers
F-350 "Face Lift" kit
Kick *** Radar Blue flames
If you could gimme that info it'd be greatly appreciated....thanks again!
Mods:
K&N Drop in filter
beastie and I have the same general truck except for ours are extra cabs, get a timing light and advance the timing is a good free mod. run good fuel the better the fuel the better it will run. no bargin gas as it is not really a bargin. A trans go shift kit is around a hundred dollars and you can install your self makes a nice impovement. there there is underdrive pulleys for around 70 dollars and a super chip for 235 i think.
How much do you advance the timing? I already have a timing light (for the race-car
)..And UDP's only $70? Thats not bad at all..I'll have to look into that. Also, what is the Trans kit? What does it contain and whats it do? Thanks again.
take the timing to 14-15 degrees and you need to disconnect the spout connector,
the transgo makes your truck shift much more agressive. it will even let you shift it like a manual if you want. it was a easy install i did the shift kit and switched to synthetic at the same time.
mike troyer at www.troyerperformance.com has a long line of bolt on items for our trucks, he is allso superchips_vender in the forums you will find him the chip forum. he has the UDP for 70clams.
i allso cut the bottom off my air box to give it a nice intake sound. i don't know if it helped power, hell it might have hurt it some but is sounds nice.
why don't you have enough time to search? there is lots to find out if you use the search function.
No pics yet...hopefully the end of this week I should. Thanks for all the help sofar..its greatly appreciated...but does anyone know the stock specs of a 94 F150 5.0? HP/Torque?
Originally posted by 94 F-150 302
Oh yea, sorry I forgot to tell you what the Face Lift is...it is a fiberglass Hood, Front Bumper, and Grill, made to look like a new F250-350, on a 150..its pretty sweet.
Should hopefully have pics up tommorow. Gotta borrow a digicam, i'll have pics up IF he remembers to bring me the digicam
Untill then I'll tide you over with pictures of my rice-mobile, seen as thats what most Truck guys call it
Originally posted by mxhotshot
look guys a pedal car...........
On another note, I dominated a suped up Chevy truck last night (in my pedal car) haha...they are way slow.
