wiring diagram?
Old Jul 10, 2003 | 10:12 PM
closer9's Avatar
wiring diagram?
Hey, does anyone know where I could find the wiring diagram for a mid 80's Bronco/F150 digital clock? Please?
thanks, guys...
Old Jul 11, 2003 | 01:34 AM
PKRWUD's Avatar
What are you trying to do? What do you need to know?
Old Jul 11, 2003 | 02:13 AM
closer9's Avatar
I'm going to put a clock out of an '85 Bronco in my '03 F150. Just wanting to know which wire is hot, ignition, and I'm assuming dimmer...
Old Jul 11, 2003 | 08:17 AM
Ford4ever's Avatar
Looks like Black is ground, Brown goes to headlight switch pin R and pin 7 of the igntion switch on the bronco ( i am assuming that this is the dimmer wire??) Lt green with a yellow stripe goes to the right door switch on the bronco. The white wire with a purple stripe goes to power. If your confused let me know and i will scan the wiring diagram for you. The diagram is out of a haynes book so it's almost impossible to understand.
-Jon
Old Jul 11, 2003 | 09:25 AM
closer9's Avatar
Thanks, Ford4ever...
That should get me going in the right direction... I'll let you know if I run into any problems...
