vapor lock
vapor lock
have a 96 f150 with dual tanks when sits for a while will have to turn on and wait couple minutes for what seems to be fuel pump to catch up does it on both tanks also sometimes when driving will turn off and have to let set with key on couple minutes seems like may be vapor lock but have no idea any suggestions
yeah, it's a fuel pressure issue, rather than vapor lock. You really need to check the fuel pressure both when it's running, and after you turn it off. You want to see how fast the pressure bleeds down after the key is turned off. A volume test may be necessary as well, but read the pressure first.
Take care,
~Chris
Take care,
~Chris
on
