89 302 Missing Under Acceleration
My engine was rebuilt about 2 years/20,000 miles ago. It ran perfectly until a few weeks ago. All of a sudden, it developed an intermittent dead miss that I corrected with new plug wires. After that, the miss was gone, but the truck was still a little sluggish.
About two weeks later, the truck idled and cruised smoothly but started to miss again. Instead of a dead miss though, this miss only occured under acceleration. In some cases, with larger amounts of throttle, it would backfire.
Last week, I replaced the plugs, cap, and rotor. All 8 plugs looked exactly the same with no evidence of any problems. I also gave it two bottles of fuel system treatment. These changes helped it idle and cruise better, but I'm still getting the same misses & backfires under acceleration that it had before last week's work. I don't think that it's a fuel system problem because if gas wasn't getting dumped into the cylinders, then there wouldn't be any be backfiring.
Since I have replaced all of the cheap & easy tune-up type components, the only thing I can think to do is check the codes. Before I do that though, does anyone have any ideas on what else to check?
Someone else said crossfiring, I'll check on that too.
Dumb question here - what's a sprout connector? I'm definintely not a mechanic, but I've messed around with cars for a long time and never heard that...
I haven't checked for codes yet, but I'm pretty sure I will have to. I'm just trying to go through all the possibilities before I go to the codes...
My hunch is that my timing isn't advancing like it should under acceleration. Since the advance is electronically controlled, I'm worried that my EEC computer is bad...
