Need help with Wiring
Old Aug 28, 2003 | 07:40 PM
MAtkisson's Avatar
Question Need help with Wiring
Does anyone know where I can find the Tach wire on my 1990 Ford F-150?? I am 95% complete with my remote start installation, but I can't find a good wire to use for the Tach. The install directions I have say that there should be a Dark Green w/Yellow wire at the coil. I see 2 wires at the coil and one is a Tan or Yellow color and the other is Red with Green. I also tried to use a multimeter to find out which wire had less than 6 volts, but both of them were over 12V. I even tried to get a signal from one of the injector wires, but both those wires measure over 12V too.
Please help.....................
Old Aug 28, 2003 | 11:03 PM
Ford4ever's Avatar
The injectors will always have 12 volts available to them, the ecm provides the ground to complete the circuit. I don't remembetr exactly which coil wire you need to use but i will take i look at my truck tommorrow and see what wire i hooked the tach pickup to.
-Jon
Old Aug 28, 2003 | 11:43 PM
PKRWUD's Avatar
The signal for the tach is not the red wire, so in your case, it's the tan or yellow wire.
