PDA
View Full Version : Pre-1997 Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40
  1. fuel system woes
  2. Truck won't start
  3. 87-91 Clear Corners and new 4x4 decals
  4. what is it Clicking/rattle
  5. Loss of Power, oil in air cleaner, runs poor cold.
  6. Cruise Control will not operate
  7. gages 94 F 150
  8. Parts cross over
  9. Request info on replacing the rear fuel tank
  10. The superlift 6" lift
  11. hub removal
  12. buying a pre1997
  13. wheel caps
  14. speedometer
  15. What was the last year of the F150 solid front axle?
  16. Twin Turbo?
  17. 1990 fule consumption
  18. 6inch lift questions
  19. replacement carburetor
  20. Air Charge Sensor
  21. Throttle body plate
  22. is my 94 5.0 f150 sd or maf?
  23. how do you know if u-joint is goin?
  24. TTB dana 44 tear down info??
  25. Engine dies when warm
  26. 1987 F-150 XL tailgate panel letters??
  27. Broken A/c
  28. How much weighs a.....
  29. 96 Daytime Running Lights
  30. Gas prices outrageous!!!
  31. 1989 Ford Bronco
  32. Stock 302/351 2wd quarter mile times
  33. Dana 60 Swap & 4.10 Fuel Economy (2 parter)
  34. Anyone lookin for a bronco??
  35. 89 femal owner distressed
  36. '82 F250 4.10's to '94 F150 8.8" Rear-end
  37. New member and owner
  38. Front clip compatability
  39. Can't 'fill-er-up' !
  40. Vacuum?
  41. A/C squealing
  42. Sending unit questions.
  43. Clanking noise from driveline...
  44. Windshield washer sprayer pump
  45. IAT Sensor location?
  46. My Truck Idles High
  47. o2 sensor
  48. sound indentification
  49. High Lift Coil Springs "1996 F150 Extended Cab"
  50. 1967 F100 4x4 conversion
  51. Posting pics?
  52. Removing and replacing head lamps?
  53. Fuel filling problem!
  54. idle speed rpms
  55. 5.8 to 5.0 prob.
  56. Electric rear sliding window
  57. '91 4.9L Jerks hard on gear change
  58. Shift Linkage Needed!
  59. '95 F150 vehicle lurching...fuel delivery problem?
  60. '90 F150 6-cyl 4.9L battery, charging system
  61. 5-spd 4.9L 6-cyl: leaks at oil pan gasket and rear tranny seal
  62. horn
  63. Slack in My Steering Wheel Need help pleaseeeeeeeeeee
  64. '90 4.9L 6 cyl PCV location, surge
  65. Alternate ratio steering gearbox
  66. Coolant Recovery Bottle Throwup
  67. 91 F150, 4.9L Jerks at gear change
  68. Headliner, where to buy one??
  69. f100 wiper switch
  70. Now what?
  71. How do I go about fixing this???
  72. squeaking noise
  73. Ford tailgate reflector.
  74. Fuel pump
  75. Flex-a-Lite Dual electric fans specifically made for our trucks???
  76. Leak at Transfer Case
  77. dumb alternator question
  78. which...
  79. Trouble replacing spark plugs
  80. Engine Wiring Harness for 4.9L
  81. Setting the clock????
  82. Fuel Pump
  83. Newbie! You guys are awesome
  84. Help I can't cure this issue!!!!!!
  85. Replaced Fan Clutch, now it Makes a Loud Whine
  86. Loose Shifter
  87. 'Packs With True Dual Straights
  88. 95 F-150 302 Manual Trans - Jerking or Missing in Cruise or around town
  89. Dodge 1500 HEMI
  90. Code 44- Air System Failure
  91. trouble starting after engine is warmed up
  92. 95 F150 stuck in park, any ideas????
  93. Exhaust System Leaks
  94. Auburn or Eaton 8.8 LS - best price SoCal?
  95. PW motor question --->
  96. Truck is getting lifted.
  97. Buying a '92 F-150 Ext. cab 302, I got questions first
  98. Computer Swap
  99. I-6 4.9 cats
  100. 1996 F150
  101. High-temp. paint for headers....
  102. warm start / idle problem want to clean ports
  103. My New Toy
  104. WTB: Triangle window next to Drivers side windwow
  105. '96 F150 Fuel Gauge
  106. New here, need lift kit info
  107. Low Oil Pressure...
  108. Help!!!
  109. 89 I-6 ticking noise
  110. 85 wipers only work on high
  111. 77 f-100 brakes
  112. 93 F150 4x4 Brake Lines?
  113. 93 F150 Transmission problems
  114. seat options
  115. window sticker
  116. Headers w/GT40P heads on '95 5.0 4x4 Supercab
  117. gas milage
  118. vibration
  119. 1996 Ignition Upgrade on a 4.9?
  120. 5.8 liter vs. 5.0 liter
  121. Bad gas or transmission?
  122. Decent/Economical Headers for 5.0...
  123. 1994 5.8 Specs
  124. freeze plugs/ water pump
  125. Anyone have spare parts?
  126. To Izzyeddy
  127. Another 4.9 mileage?
  128. 94 powerstroke WONT START!!
  129. Gas Leak
  130. How much hp
  131. Blown Fuses!
  132. 1978 4x4 headers
  133. Excitement about restore (Motor Question)
  134. Odometer
  135. 5 Spd Shifter
  136. 351W measurements
  137. New motor soon for my truck...
  138. UH oh
  139. Aftermarket Radio Install Question
  140. 94 5.0 rough start up
  141. bad gas mileage
  142. no heat
  143. Inertia switch location 1987 F150? (wont start)
  144. Covering my head
  145. anyone removed an EFI Inline 6 Head?
  146. ram air?
  147. 1978 F150 For Sale
  148. Timing mark 5.0
  149. Fuel mileage and gutting cats
  150. changing parking lights-help
  151. Fuel mileage w/I-6, E40D
  152. 1989 E-350 Exhaust System
  153. Wanna remove my smog equip
  154. New F 150 Owner
  155. gas tank repair..
  156. Fuel Injectors
  157. Cheap power?
  158. Replacing fuel pump
  159. One of those mods..
  160. Got a new truck!
  161. really bad fuel economy
  162. Found one elec problem, still huntin the other
  163. 1989 5.0 stall problem
  164. 5.0 performance / mods?
  165. Put custom exhaust on
  166. 300 I6 hot starting problems
  167. 94 F-150 5-spd. driveline ticking...
  168. EVAC solenoid
  169. engine stalls
  170. lowering a 1970 f-100
  171. F150 build up... ?'s
  172. Turbo Diesel
  173. Starter Solenoid hot--then won't start
  174. 93 F150 no crank problem
  175. High pressure in fuel tank?
  176. Water pump fixed, afraid of new problems!
  177. Ever heard of a problem like this?
  178. What Next?
  179. Fuel problem question
  180. Wire Diagram
  181. Dont take any of that stuff off
  182. 300 I-6 RPM's
  183. compression test is 180psi good?
  184. Oil Pan Gasket
  185. upgrade towing performance - mods?
  186. Ford 1994 Lightning
  187. Odometer Memory storage?
  188. fresh 5.0 problems-surges
  189. Limited slip differential
  190. seafoam - locating brake vacuum booster
  191. Advantages/Disadvantages of an I6 w/ 2.47 rear?
  192. 89 F150 won't start
  193. Good luck Polaris! Another Question about Water Pumps
  194. 95 F150 loses power
  195. 4x4 Front Hub Change
  196. F150 Vacuum lines???
  197. TV Cable On 94 f-150 With 351W
  198. Water pump calls it quits
  199. EGR Valve Replacement Follow Up
  200. American Racing Outlaw wheels, available in 16x10 and polished/chrome?
  201. '89 F-150 5.0 running dirty
  202. 1989 F150 I-6 Stalling
  203. EGR Valve Replacement Question
  204. Gauge cluster w/tach swap #2
  205. 1988 302 w/AOD tranny into 1981 F-100
  206. airbag replacement
  207. 1994 351W to 302 Engine Swap
  208. Clutch probs
  209. Power drain when ignition is off
  210. Attn: Powertrain Gurus (re: 351/AOD)
  211. HELP! - some electrical dead in the cold.
  212. another dual tank issue
  213. 1990 F150 Seat
  214. replacement front seat ?'s
  215. First morning start idle
  216. 94 5.8 Question
  217. Preempetive maintenance beyond normal tune up
  218. Not much heat. What gives?
  219. Inline 6 Engine Codes?
  220. confused 5.0
  221. Removing gas tank
  222. Need help with clutch
  223. 1991 f150 302 newbie question
  224. New here but not to fords
  225. 80-96 4x2 lift
  226. Not impressed with Magnaflow sound
  227. 92 Fuel Crossover problem
  228. Cylinder head time
  229. Repair manuals??
  230. I cant find an air intake kit for my truck..
  231. hi-perf heads
  232. Weird.....
  233. 92-96 F-150 sucks???
  234. 1/4 mile performance
  235. monroe gas magnum
  236. Air Injection Rail
  237. what model truck?
  238. Earls brake hoses are in!
  239. Some new 1/4 times
  240. Timing question
  241. make a 88 front to a 92, bronco
  242. plastic radiator
  243. Anyone heard of a RAFF valve for brakes
  244. tread separation
  245. Newbie with brake problems 1993
  246. Please Help
  247. EGR Cleaning???
  248. Best place to buy Gears
  249. New Bronco Concept (Sorry if this is a repost)
  250. My old truck rolled
