1/4 mile performance
First off. Great Forum. Wish I had found it before I started my modifications.
My truck is a 1994 Ford F150 shortbed. It has a 302 with factory mass air, 470Rw Auto Trans, and stock 3.08 gears. The shortblock is stock with the exception of a Crane 2020 cam. I have had the heads professionally ported, I had the flow numbers but I can't seem to find them right now. I have added the upper and lower Edelbrock truck performer manifold, BBK dual 56mm throttle body, roller rockers, shorty headers, Dual exhaust. K&N Filter, underdrive pulleys, and level 10 shift kit in the trans.
My best time slip so far is:
R/T .673 (oops)
60 2.495
330 6.863
1/8 10.462
MPH 68.77
1000 13.523
1/4 16.158
MPH 84.45
I have a set of 3.73 gears that I just have not had the time or money to get in. I have been looking at the granatelli larger mass air sensor, but they are expensive. Anybody know if they are worth it? I have also been considering a chip? But am at a loss as to which one to get?
At this point in time I can put about $500.00 more into but I want to be solidly in the 15's. Your suggestions and comments would be very appreciated. Thanks.
R/T .673 (oops)
60 2.495
330 6.863
1/8 10.462
MPH 68.77
1000 13.523
1/4 16.158
MPH 84.45
Nice times....very similar to mine. From comparing them, I come off the line better but you are pulling alot better on the top end.
R/T - .187
60 - 2.215
330 - 6.610
1/8 - 10.258
MPH - 67.87
1000 - 13.433
1/4 - 16.159
MPH - 82.31
My mods:
Underdrive Pullies
Air Filter
Long Tube Headers
True Dual Exhaust
3.73 Gears
2200 Stall converter
TransGo Shift Kit
Uve done some internal stuff.....thats what I am planning on doing.
R/T - .187
60 - 2.215
330 - 6.610
1/8 - 10.258
MPH - 67.87
1000 - 13.433
1/4 - 16.159
MPH - 82.31
My mods:
Underdrive Pullies
Air Filter
Long Tube Headers
True Dual Exhaust
3.73 Gears
TransGo Shift Kit
The 3.73s dropped my 60' from 2.4s to low 2.3s/high 2.2s. And 1/4 from, 17.1s to 16.6s. So they helped out alot. The gears were a nice mod. I went from 3.31s to 3.73s.
I want more!!!!!
I'm looking for high 14s all engine., but still being reliable enough to tow my boats when I need to. Too many very mildly modden Gen 1 Ls are beating me. Most of them around here are running 14.9s-15.1s. And well then I got my friend with the turbo....but he's in a league of his own. I still have a long time before I am going to do anything major. I want to run some 15s with only bolt ons.
I hate you guys with factory roller motors and already larger cams!
If I'd had a roller motor stock I'd have tossed in a stock 302HO cam when I had the front off for a water pump change. I do have the nubs for the spider tray they just aren't drilled or tapped.
I wonder if I could drill and tap them?
Ah well, I have a good lead on a good 1995 roller block I am going to try to get. If I get it, I will get some decent heads <$450 so I can make 275-300hp.
