1996 Ignition Upgrade on a 4.9?
Old Mar 17, 2004 | 10:44 AM
boobar's Avatar
I have been reading the posts about ignition upgrades and the jury is apparently still out on how much of a difference it makes. I have a 1996 F-150 with a 300/6 and the truck has 95000 miles on it. I have put a K&N FIPK kit on it and that is about it for engine modifications. I am looking to Troyer for an electric fan to replace my stock clutch fan and they have an ignition upgrade from Accel that claims to give a few HP increase. Is it worth the $135.00 for the coil, wires, cap, rotor, and plugs, will I see a noticeable performance increase? Let me know what you guys have done to your trucks as far as ignition upgrades and what kind of performance increases you have seen.
Old Mar 17, 2004 | 10:53 AM
UrbanCowboy's Avatar
Well I installed an MSD 6A ignition and new MSD wires a couple years ago and I noticed the difference. I just installed one in my friend's Pathfinder along with an ACCEL ignition coil. He says he really notices the performance gains. I'm going to get a new coil for mine now, just trying to figure out which I need.
Old Mar 18, 2004 | 12:26 PM
PKRWUD's Avatar
Unless your coil is wearing out, which it may be, you won't notice a difference. However, you will have peace of mind that your ignition system is in good shape. To me, that sounds like a worthwhile investment.
Old Mar 18, 2004 | 07:43 PM
boobar's Avatar
That is kinda what I was thinking, the replacement Accel coil for a TFI is only $50.00 at Advance Auto, the MSD one is $5.00 cheaper than that, does anyone have a preference for either one?
Old Mar 20, 2004 | 12:24 AM
SPROCKET_X's Avatar
That Accel kit Troyer has is a complete rip-off...I got the same kit from Summit for $60.
Same with the Troyer fans(which I have)
You can put together the same exact kit Troyer sells for under $150, plus Troyer doesn't have directions for Pre-97s so you have to do it on your own, I can guide you when the time comes, you can get the exact same controllers form Pepboys for about $30 each and Derale fans for $30-$60 if you shop around (E-Bay).
And the mounting kit that comes with Troyers SUCK, spend $5 and get some nylon zip mounts from Napa (they will probably come with th electric fans you buy)
Old Mar 20, 2004 | 09:00 AM
StrangeRanger's Avatar
http://fordsix.com/forum/viewtopic.php?t=12844
for a good discussion on the subject of electric fans and some very good links to DIY instructions and pix
Old Mar 26, 2004 | 02:15 PM
boobar's Avatar
Thanks for the replys, I opted for the MSD TFI ignition coil along with an Optima red top battery. I got them installed a couple of days ago and the truck runs great.
