confused 5.0
Old Jan 16, 2004 | 07:36 PM
NITEPACK's Avatar
confused 5.0
I am building 5.0 h.o to go back into my 92 flareside.Question is,will changing to a H.O. firing ordrer confuse my fuel injectors as when to pulse? will I still use the same computer in my truck or do I have to change it too? Any help would be appreciated
Old Jan 19, 2004 | 09:00 PM
Jimmy_neutron's Avatar
I have a crane 2020 cam in my 94 f150 that uses the H.O. firing order. When crane recommended this cam, they said that the change in firing order would have no effect. I was wary, but I tried it out. Turns out they were right. So run your factory computer with no worries.
Old Jan 19, 2004 | 11:23 PM
StrangeRanger's Avatar
Your 92 should be speed/density with batch-fire injectors, i.e. 4 squirt at one time. On later trucks with MAF the injectors fire one at a time sequentially; with sequential firing the injector order must match the plug order
Old Jan 20, 2004 | 04:55 PM
My truck is a 94 with factory mass air and i have had no problems so far. Should I be worried?
Old Jan 20, 2004 | 06:15 PM
Doesn-t the stock MAF truck engine use the 5.8/5.0 HO firing order?
Old Jan 21, 2004 | 03:05 PM
My 94 did not use the H.O., 351 firing order. I am positive of this.
