replacement front seat ?'s
Old Jan 22, 2004 | 10:21 AM
vince vaughn's Avatar
If I want to replace the bench seat in my 93 F150, what are my options in terms of captain-type seats or bucket-type seats? I want to replace the bench and also add a nice center console as well.......thanks.
Old Jan 22, 2004 | 07:03 PM
Nite351's Avatar
You mite be able to use the seats and console out of an extended cab, not sure if there's enough depth in a standard cab tho.
Old Jan 23, 2004 | 09:26 AM
97 buckets and console
I found 97 buckets and console on ebay for a supercab f150. Will I need to drill holes in the floor pan or is the bolt pattern the same for a 93 as a 97? What about the console, drill or not?
Old Jan 23, 2004 | 12:18 PM
Nite351's Avatar
Unless it was a '97 3/4 ton I doubt that they would be the same, I believe that was the first year for the new body style for the half tons. The best thing to do would be to ask somebody with one to let you do a little measuring.
I really can't say whether or not they changed the seat mounts, it'd be best to check first.
Old Jan 23, 2004 | 12:35 PM
notchstang92's Avatar
There is a place in western MA that sells a full bench seat for 96 and older F series that has 2 buckets built into it and that center section where the arm rest is is still there, it opens for a center console. The interior color match is very good and you can get all the power options for your seats if you want. I think it runs about $700 though. My friend just put one in his 95 F250 and its very nice. I don't think it requires any drilling or custom mounting.
