clutch replacement
clutch replacement
I have a 1988 f150 4x4 supercab that I need to replace the clutch on. My Haynes manual says I need to remove the transfer case and then the five speed. I am wondering there is enough clearance to slide the transmission and transfer case back far enough to R & R the flywheel and clutch.
Thanks, I figured that was the case. The truck also has the slave cylinder mounted inside the bell housing. When I disconnect the line do I need to plug it to prevent draining the master cylinder, or does it make any difference when I go to bleed the new slave cylinder.
no, it has a coupler in there so no fluid will leak out. However, most manuals say you will not have to blead the slave, but this just isn't the case. I havn't met anyone who has disconnected this line but has not needed to blead it a little bit at least. Mine too FOREVER. Probably the most agrivating part of the whole ordeal.
