Attention Beastie
Attention Beastie
I noticed you have a mass air like my truck does. I want to put on a conical filter similar to what you did. Where did you put the sensor that goes into the top of the stock airbox? I also emailed you earlier.
Thanks in advance for your help
It simply measures the temperature of the air going into the engine. I have had no issues with it in the location I have it. It isnt permanent or anything, the sensor has 2 tabs that used to secure it into the air box, and they hold it snuggly in one of the random hole on the mounting bracket I mentioned before. I'm sure the temp it is reading is pretty close to whatever the temp going into the engine is, cause the filter is like 3 inches away.
