squeaky steering???
Old Mar 7, 2005 | 06:20 PM
FordF150Dan's Avatar
squeaky steering???
when i turn my steering wheel it squeaks most of the time (sometimes not on warmer days) but most of the time it is squeaking.....would this be the steering gear box or something of that matter?
Old Mar 7, 2005 | 10:28 PM
Yankee7985's Avatar
Probably tour pitman arm. Known problem. You can either inject grease into the dust boot or replace the arm.
Old Mar 8, 2005 | 06:05 AM
5Lbronco's Avatar
Or tie rod ends
Old Mar 10, 2005 | 09:52 AM
cleat's Avatar
Inside or outside the cab ?
If inside problem is the sliding contacts for the horn / cruise need a little lube.
If outside probably a bad ball joint.
Old Mar 11, 2005 | 04:15 AM
5Lbronco's Avatar
Its prolly tie rod ends well known problem
Old Mar 23, 2005 | 04:48 PM
kdgncop's Avatar
mine is on the inside whenever i turn the wheel at all. sounds sorta like a spring in there stretching or such. how do you "lube" the sliding contacts?? what sourta lube do you use?? don't want to try the wrong place and then on the first warm day have shtuff dripping down off my steering column! thanx in advance
Old Mar 24, 2005 | 07:44 AM
cleat's Avatar
you either have to take off the plastic steering column cover or pull the steering wheel. You will then be able to see the copper rings on the back side of the steering wheel. You can use either white grease or a little motor oil. Just a little is all it takes.
Old Mar 24, 2005 | 11:58 PM
Chris Currie's Avatar
Is it a squeak or a squeal?
Check the power steering fluid.
Old Mar 26, 2005 | 03:49 PM
gsapatka's Avatar
Have the same thing in my 05. Seems to be a plastic on plastic sound. Do you think it might be the same contacts?
Old Mar 27, 2005 | 08:06 AM
cleat's Avatar
I think your 05 would use a ribbon cable instead of contacts. You are hearing the ribbon calbe in it's holder. I don't think you can do anything about it.
