My new motor has arrived...
Well after much thought, research, and WAITING (Thank you Comp Cams for making me and my engine builder wait 36 DAYS for an "off the shelf" XE grind cam!!! Guess I'll use someone else next time) my new 327cu stroker has arrived. I have a photo of mock up before actual final assembly of all accessories, but unfortunately attachments are disabled and the gallery is having maitenance done, I'll try again later. Power "guestimate" for this combination is 320hp & 380ft-lb, will post dyno results after break-in and fine tuning. My performance rebuild of the AOD is being completed as I type this which includes all "the right stuff", too much to list here. I will try and put specs and other photos in a gallery if I can figure out how to do it (yea, I'm a newbie to this stuff). Hope you guys are as stoked as I am, can't wait to share all the results with a bunch of fellow enthusists who can appreciate the hard work! More to come!!!
Well crap!!! I still can't make an attachment or create a gallery because admin says it's still being maintained, don't know what's up with that, maybe admin can shed some light on that (hint,hint). Any way here is my spec sheet I copied in from Microsoft Word.
MOTOR: Central Coast Mustang
• CCM longblock
o 327cu stroker short block
New Ford 5.0 standard bore block (4.00”)
Scat cast steel stroker crank (3.25”)
Probe Forged I-beam rods (5.40”)
Probe forged pistons with Childs & Albert ZGTF total seal rings
GT40P heads with 3-angle valve job
Manley stainless steel undercut valves
PC positive lock valve seals
Comp Cams Double springs
Comp Cams 10 degree keepers and retainers
Comp Cams Roller camshaft (XE258HR) / 2 degrees advanced
Advertised duration / 258 in / 266 ex
Duration @ .050” 208 in / 216 ex
Lift with1.7 rockers / .566 in / .578 ex
Lobe separation angle (LCA) 112 degrees
RPM operating range / 1300-5300
JP billet steel multi-index double roller timing set
Crane 1.7 roller rockers
28oz imbalance flex plate and harmonic balancer
CCM / Mac GT40P truck shorty headers
Edelbrock 5.0 truck intake kit
• Edelbrock 5.0 truck twin 56mm throttle body
• 24# injectors
• Adjustable fuel regulator
• New Ford TFI distributor
• Crane HI-6S ignition with PS91 coil
• New Ford 3G alternator (160amp)
• New Ford radiator (HD 2-row aluminum)
• Flex-A-Lite dual electric radiator fan kit
• All new sensors
• Mass air conversion kit
• C&L mass air meter 76mm with 24# calibration
TRANSMISSION: Cypress Automotive
• Performance rebuild existing AOD
o Complete disassembly, cleaning and inspection.
o Replace all worn service parts
o Add or upgrade the following:
TransGo HD shift kit
Hardened lock-up shaft
Wide ratio gear set
Additional clutches in direct clutch drum (8 total)
2” Kevlar lined overdrive band
A servo
Improved sprag
Mechanical Diode
Finned cast aluminum deep sump pan with drain plug
HD torque converter with welded vanes
o Blueprint and assemble
REAR END: Cypress Automotive
• Performance rebuild existing rear
• Complete disassembly, cleaning and inspection
• Replace all bearings and seals with new
• New Torsen diff
• New TA girdle cover
• Redline synthetic gear oil
Also of note, you may recall my first post way back asking about high flow fuel pumps, well I found some. Master parts, who sell through AutoZone makes in tank replacement fuel delivery units (that's your in tank pump assembly for you 92-96 guys) that flow 50 GPH or 190 lph. StrangeRanger, I know we talked about this before, but as you can see the mild rebuild grew into a beast, I couldn't help it. (he,he,he!!!)
As to the AOD, the main things to upgrade are the thin lock-up shaft to a hardened one, replace the break prone spring and roller 2nd gear assembly with a mechanical diode, a wide ratio gearset which comes with the stronger 2" overdrive band, better "A" servo for increased band clamping force, add additional clutches to the direct clutch drum, and a deep sump pan for additional fluid for improvedd heat control.
Do all that and you should be able to beat the crap out of it as long as you maintain it well (change fluids and DON'T OVERHEAT!)
Whew! My fingers hurt.....
• CCM longblock
• 24# injectors
• All new sensors
Wide ratio gear set
A servo
Improved sprag
Mechanical Diode
• New Torsen diff
I wondered when I would see someone do a stroker? Did you buy just the short block from CCM? Post up your dyno numbers when its done. Also your tranny. I did a rebuild on mine about 30k ago and its started to give me some problems. So much for a stock rebuild
FINALLY!!! Thanks to Admin, guess you fixed the bug, because I was finally able to make a gallery.
Anyway, you can now go to my gallery (just search for "Fast Pony") and check out the engine photos and my truck. I will be adding more as the project moves along.
Enjoy and let me know what you think!!!
here's a link to his gallery, guys...
https://www.f150online.com/galleries....cfm?gnum=2444
looks good!!!
looks good!!!
Beastie,
They are Mac headers. I purchased them from CCM as part of a package deal. Here is a link to Mac page for the model number:
http://www.macperformance.com/macsto.../f-series.html
CCM (Central Coast Mustang in California) sells them for $219.00, you might find a better deal searching on the web, but based on Mac's suggested retail price on their web site, that price is pretty good.
The kit comes with the headers, black oxide header bolts, and nice embossed copper gaskets. They are HTS high temp paint coated, not as good or as nice as ceramic, but it works.
I looked at your exhaust pics (nice job) and it appears headers are all you are missing. By the way, the stock manifold opening is only 1-7/8" in diameter and so is the Mac header at the ball flange. This is because the stock Y-pipe is so small. I have done surgery to the Y-pipe to make it 2-1/4" like the rest of my system and opened the ball flange to match. Looks like you are already there so all you would need to do is open up the ball flange.
Other than that they fit good and you can actually get to the spark plugs OK unlike most equal length Mustang shorties.
