Whistling brakes
Old Mar 30, 2003 | 06:55 PM
kuhnbrady's Avatar
Whistling brakes
i have a 93 f150 and the brake on the right side makes a high pitched wistling when i'm going forward but not backward i took the wheel off to see if i could figure it out but the rotor wasn't damaged. does anyone know what i can do to fix it
Old Mar 30, 2003 | 09:34 PM
Ford4ever's Avatar
Sounds like something with the pad mounting hardware causing the pads to move and vibrate when going forward. I would take the caliper off and take the pads out and lube up all the hardware with anti-seize or silicone grease. Also put some of that stuff on the back of the pads then put it all back together and see if the noise is gone.
-Jon
Old Mar 31, 2003 | 10:59 AM
ccnseven's Avatar
Did you spin the axle? Sometimes a bearing can start off making a whistling type noise. Hope its just a brake part like fordforever suggested
