window question
Old Feb 7, 2003 | 09:58 PM
GILTYLER's Avatar
Question window question
Hi
I am looking at a 1990 f150 lariat king Cab truck.
It has 104.00 thousand miles And is Clean and straight,the power windows do not work you can hear the windoe motors run but they do not move up or down.
the motor is a 5.0 and has a aod trans tilt cruise power locks.
the asking price is 3,200 I may be able to get it for a little less.
Is this a good price Any ideas on the window trouble.
Please help
GIL
Old Feb 7, 2003 | 10:37 PM
dave186's Avatar
I havent looked at one of these trucks window motors yet, but if its like my 1990 Tbird, inside the motor are some little rubber puck type things that will wear out eventually. I think they are maybe some sort of safety thing, but the ones on my tbird just rotted away. I took the small cover off of the motor and found that a 7/16ths nut fit in the slots perfect. Its kind of crude, but it worked.
Old Feb 8, 2003 | 09:27 AM
Macgyver's Avatar
yes the rubber bushing in between the gears get brittle over the years and just disentigrate , i carved some small hardwood blocks to replace them , worked great . !!
Old Feb 9, 2003 | 03:13 AM
Miles's Avatar
Yeah, those little plastic "pucks" go in them. I replaced my motors with motors from a 91 Explorer and they work better than they have since I got the truck. Its a '92 Flareside.
Old Feb 9, 2003 | 11:05 AM
Macgyver's Avatar
lol. i work on RV's so i used an electric step motor to replace mine . not only can i get them cheaper then a window motor but they are pretty much an exact replacement. well except i had to install and wire it backwards for the drivers door.......lol
