need help!!
Old Mar 21, 2003 | 12:39 PM
RedInline6's Avatar
need help!!
damm truck crapped out just now!! i was going fine and shifted from 2nd to 3rd and it stalled out. won't start again. all sensors are plugged in, it's got gas and spark. 300 6 w/ efi on a 94 f150 4x4. starter spins it just won't turn over. any ideas? it's parked on the side of the road right now.
Old Mar 21, 2003 | 11:20 PM
topgun3208's Avatar
sounds like your starter drive needs replacing, not an expensive fix, been there, done that
Old Mar 22, 2003 | 01:44 AM
RedInline6's Avatar
i'm going to check it out tommorrow. had it towed today. i hate having vehicles towed!!!!
Old Mar 22, 2003 | 12:58 PM
RedInline6's Avatar
ok it started fine today. i'm leaning towards the fuel pump. where is the fuel pump shut off switch and how would i reset it. my truck didn't come with an owners manual. thanks!
Old Mar 22, 2003 | 06:57 PM
SPROCKET_X's Avatar
The fuel shuut off (inertial switch0 is located behind the passenger side kick panel, but that wouldn't be it if it started again.
Old Mar 23, 2003 | 02:09 AM
RedInline6's Avatar
well the damm thing tried to stall again tonight. when i put a load on the engine ( release the clutch) it sputters and tries to die. if i reeeeeeaaaallllllly slip the clutch i have no probs. here's the thing. both times it happened it's been cool and damp. it feels the same way my old dakota did when it had water in the dirtributor cap. so that's my next avenue to explore.
Old Mar 24, 2003 | 12:11 PM
Fast Pony's Avatar
So when's the last time you changed your fuel filter???
Clogged filters start OK because the crap that's in them settles on the bottom, once you get going it all swirls around and collects on the paper element and restricts flow often resulting in the symptoms you are experiencing. That's usually why it will start again after sitting for a while. If it has been more than 20,000 miles or never at all, you need to replace it.
