difficulty starting truck
Old Feb 27, 2003 | 01:39 AM
old truck's Avatar
I have a 1985 f150 302 engine fuel injected. The problem I have is starting it when it is at normal operating temperature.
It starts fine when it is cold. I will go on an errand stop it lets say for half an hour and when I try to start it. I have to crank it over three to four times wait between ten to fifteen seconds crank it over again and then it will start. I need help Please.
Old Feb 27, 2003 | 10:24 PM
Miles's Avatar
Do you have any warning lights at all? How does it run when it runs? Can you smell gas? Does it spit and sputter? Some more info might get you closer to an answer. It could be any number of things.
Old Feb 28, 2003 | 09:54 AM
ccnseven's Avatar
timing can cause a similar problen
Old Feb 28, 2003 | 07:07 PM
SPROCKET_X's Avatar
I went throught the same problems just recently, ended up being my stock battery finaly going out at 115k, replaced it with a red top optima.
Old Feb 28, 2003 | 09:27 PM
Miles's Avatar
Could be the electronics box on the fenderwell. They don't always just "quit".
Old Mar 1, 2003 | 02:27 AM
Shawn93's Avatar
Sounds like fuel may not be reaching the injectors.Try turning key on for 5 seconds,off then on 5 seconds and so on for about 4 or 5 times and then see if it starts.
Old Mar 5, 2003 | 02:04 AM
old truck's Avatar
to miles .
There are no warning lights coming on the dash board and they all work.
Thanks for the tip on the electronic box on the fender well.
old truck
Old Mar 5, 2003 | 02:08 AM
old truck's Avatar
to ccnseven
Thanks for the tip on the timming as soon as i can find a timming gun if they still make them i'll try it.
old truck
