oil pan gasket ???
Old Apr 11, 2003 | 01:15 PM
drm7's Avatar
oil pan gasket ???
I had my truck in the shop and they noticed that I have a small leak on the oil pan gasket. They said that some motors actually have to be lifted to pull the pan off for a new gasket. Does anyone know if this needs to be done for my truck? It's a 94 short bed, regular cab, 4x4, 351w, auto, a/c, w/manual hubs. That should be enough info to describe the truck.
Thanks!
Old Apr 11, 2003 | 07:24 PM
inski21's Avatar
I believe it does need to be lifted slightly to clear the front axle and drop enough to clear the oil pick-up. But the engine doesn't need to be pulled, just lifted off the mounts enough for the pan to go down and backwards.
Old Apr 14, 2003 | 12:30 PM
Fast Pony's Avatar
Yep, gotta' jack the motor, might even need to remove the intake on 351. It just doesn't want to clear the bell housing without lifting the motor. PAIN IN THE *** JOB! Done it twice on 5.0 motor.
Old Apr 21, 2003 | 09:24 PM
tedm's Avatar
I have the same truck as you, but with a 302. They had to lift my engine up a bit and really had fun when they realized that my aftermarket exhaust had been welded on. It had to be welded back on afterwards, of course.
Old Apr 22, 2003 | 05:24 PM
Libom's Avatar
Yep, it is a pain in the **** !
Old Apr 24, 2003 | 01:21 PM
drm7's Avatar
Thanks for the info.
The leak seems to be pretty slow right now so I'll just keep an eye on the oil and if it starts leaking too fast I'll get it fixed.
Old Apr 24, 2003 | 07:41 PM
Libom's Avatar
could possibly need just a little snugging.
Old Apr 27, 2003 | 07:09 PM
Tim in OH's Avatar
Unhappy
Like the others said, sorry to tell you but I imagine you do have to jack it. I have a '92 F150 with a 300-I that has has a minor leak. The actual intructions in the manual for a oil pan gasket replacement says, "remove radiator, remove starter, unbolt motor mounts, raise the engine". This combined with a few other problems and I am considering selling it and buying a late model used truck.
Old May 1, 2003 | 10:50 AM
Pre-Runner's Avatar
Regarding selling truck vs oil pan gasket on 4.9.
If you don't have wrench skills ( and alot of patience ) don't
attmpt this. Just jacking up the engine on the 4.9 will not let
the pan clear. You also don't really need to remove started or radiator. Mine took me about 4 hours I guess. It was worth it.
I don't have a truck payment and I've got 197K+ now.
Just my opinion.
Old May 3, 2003 | 05:36 AM
JDMIDNITE's Avatar
Oil gasket and performance question
I am just starting the upgrade onn my 1994 ford F150 XLT 5.8L. Did headers, cat back exhaust and K&N air system. Did you upgrade chip or still factory? Change plugs?
Thanks for the oil gasket info, same issue leakingoil gasket
Thanks for any help
Jim G.
