Rear ABS Light
Old Feb 4, 2003 | 03:24 PM
Arvin J.'s Avatar
Rear ABS Light
1992 F-150 5.8 Litre Rear ABS light comes on after about 30 to 45 seconds after start up. It does not go out. Any ideas what the problem might be?
Old Feb 4, 2003 | 09:11 PM
FORD302GUY's Avatar
About 90 percent of the time it is the sensor on the rear end. It is only like 12 dollars from ford.
Good Luck
Old Feb 4, 2003 | 11:48 PM
dave186's Avatar
mine came on the other day after i tried to make my truck a submarine. I had to pull a toyota out of a creek and the water was up to my bumpers. after the drive home, it hasnt came back on.
Old Feb 5, 2003 | 12:40 PM
ccnseven's Avatar
Arvin J, does you speedometer& cruise control work? My abs light came on and at the same time my speedo and cruise quit workin, bout 5 years and 100k miles later I was under it at a muffler shop and the wires to the vss (vehicle speed sensor) on the rear axle tube driver side were cut. I twisted em back together and the abs light went off and the other stuff tied to it works now. Not to mention my truck odometer shows 100k miles less than what it's been driven
Old Feb 5, 2003 | 12:49 PM
Arvin J.'s Avatar
I have not had a chance to check on the truck. getting off after dark and no garage to work in. I appreciate everyone's help and suggestions. I will let you know what I find.
