Need help
Old Apr 14, 2003 | 03:00 PM
FreekerXG2's Avatar
Question Need help
I just got a 1987 F150 4x4. It runs pretty good. I need to figure out what the specs on my engine is though, and I would like to put in a super charger and change to a manual trans. Any got any advice or can help?
Old Apr 14, 2003 | 03:05 PM
SPROCKET_X's Avatar
Well what engine does it have? LOL
Old Apr 14, 2003 | 03:27 PM
Ford4ever's Avatar
On a truck that old you will need to rebuild the engine before you put a supercharger on it. I don't know what engine is in it but if it's an inline 6 your out of luck.
-Jon
Old Apr 22, 2003 | 11:18 PM
FreekerXG2's Avatar
engine
Its a V8 5.0 litre. 306 block I think.
Old Apr 23, 2003 | 12:01 AM
beastie's Avatar
It would be a 302 unless it was rebuilt and bored .030 over, then it would be a 306. To put a blower on, you will have to convert it to Mass Air for starters, and will definately need a rebuild.
Old Apr 23, 2003 | 01:28 AM
Donate54's Avatar
convert to a manual? man, if i had the chance, i would trade my manual for an auto, these 5-speeds just arent very tough at all. if youre going to be building up that 5.0, my suggestion is to stay with the auto.
Old Apr 23, 2003 | 01:42 AM
beastie's Avatar
I have to agree with donate, the autos can handle alot more power, and are consitant, never miss a shift or anything, and they always launch close ot the same. If you dont care about overdrive, just make your (im assuming AOD) race built. It is really cheap to built those up. Otherwise, if you want to get better gas mileage via overdrive, get a race built 4R70W or 4R100. I have a rece built 4R70W, and love it.
Old Apr 23, 2003 | 04:38 AM
TF's Avatar
TF
AOD's are overdrive transmissions, hence the acronym Automatic OverDrive. Since you have an '87, if you're thinking about an auto tranny and you want an OD for gas mileage, you'll probably want to go with the AOD since they are not electronically controlled. However, if you don't care about the OD, then the C-6 would probably be your transmission of choice. BTW, do you know which transmission you have in there now? I'm sure if it's an auto it's either the AOD or the C-6. Any ways, for what it's worth I prefer having an automatic in a truck. There are so many buildup parts available for both the AOD and the C6 that it can almost be like having the best of both worlds-- performance and convenience.
Old Apr 23, 2003 | 11:34 AM
ccnseven's Avatar
I'm with stayin with the auto, I built my AOD with a superior hd shift kit and I wouldn't trade it for nothin. I like hearing the tires bark when I runnin it
Old Apr 23, 2003 | 01:29 PM
FreekerXG2's Avatar
Its not a overdrive its the other one I think It has low and high but no OD.
Old Apr 23, 2003 | 02:50 PM
Donate54's Avatar
your tranny has no OD? you must have a C6 in there then. is it a 3 speed? i dont know of any other ford automatics in trucks that dont have OD other than the C4/C6
Old Apr 23, 2003 | 07:59 PM
TF's Avatar
TF
Given the year of the vehicle and the fact that it's an auto with no OD, I'm sure it's the C6 tranny. That's a great platform to build upon! I don't know why you'd want to get rid of your C6 to put in a manual transmission. Most people swap IN the C6!!!
Old Apr 23, 2003 | 11:57 PM
beastie's Avatar
I meant C-6 not AOD, I had a brain fart, I think everyone has one every now and then LOL
Old Apr 24, 2003 | 12:51 AM
TF's Avatar
TF
Don't worry about it Beastie. I get 'em all the time
